Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum AutoCAD and ProjectWise and Raster Intergration
    • Sign In
    • Replies 5 replies
    • Subscribers 60 subscribers
    • Views 3047 views
    • Users 0 members are here
    fmcallis
    Offline fmcallis over 8 years ago
    I have a user that is using AutoCAD and ProjectWise.  He wants to have it where his raster images are being checked in and out when he opens and closes his DWG file.  I gave him the following information.  He wants to know if he needs an AutoCAD integration module installed that will allow AutoCAD and ProjectWise to work together.
    I told him that needed to edit the mcm.user.cfg file in the ProjectWise folder.  There is a section about 3/4 of the way down that is for raster check-in/out.  You can set these how you want them to be defined.  You also need to delete the # that's in front of the variable name so it will be read.
    Try changing the following lines.
    Original lines:
    #PW_RASTER_CHECKINOPT = -1
    #PW_RASTER_CHECKOUTOPT = -1
    Change to: (Remove # and change from -1 to 1)
    PW_RASTER_CHECKINOPT = 1
    PW_RASTER_CHECKOUTOPT = 1
    You will also need to make sure you run scanref to associate the raster images to the DGN file.
    • Sign in to reply
    • Cancel
    • JackiS
      Offline JackiS Mon, Mar 30 2015 2:35 PM
      Yes, we do have integration modules for AutoCAD 2014 and 2015.  What version of ProjectWise does the user have installed on his machine?  For a list of integrated applications that are supported for each version of ProjectWise please see http://communities.bentley.com/products/projectwise/content_management/m/mediagallery/177368
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • fmcallis
      Offline fmcallis Mon, Mar 30 2015 2:50 PM in reply to JackiS
      They are running ProjectWise 08.11.11.574 and AutoCAD 2013.
      • Cancel
      • Sign in to reply
      • Cancel
    • T_Tran
      Offline T_Tran Wed, Apr 8 2015 11:12 AM in reply to JackiS
      We're currentley having the same issue, with ProjectWise 590, AutoCAD 2015 and we have the intergration module installed.
      We have to manually check out the raster image out in the ProjectWise session file manager (right-click check out) and manually check it in once the modifications are done.
      The Save image window does appear at the end when modifications has been made to the raster image. But unless I manually check the image in it will not automate the check in as it would with Microstation.
      • Cancel
      • Sign in to reply
      • Cancel
    • JackiS
      Offline JackiS Wed, Apr 8 2015 4:51 PM in reply to T_Tran
      Did you edit the mcm.user.cfg in the ProjectWise\bin folder. There is a section about 3/4 of the way down that is for raster check-in/out. You can set these how you want them to be defined. You also need to delete the # that's in front of the variable name so it will be read.
      Original lines:
      If that does not work please let me know and we'll have a remote session and figure out what is going on. Thank you!
      • Cancel
      • Sign in to reply
      • Cancel
    • T_Tran
      Offline T_Tran Thu, Apr 9 2015 3:39 PM in reply to JackiS
      Yes we have those variable set in our Customer Configuration file block, works great with Microtation but we not in AutoCAD.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
