Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum fresh installation of PWss4 in windows 2008r2 64bit server
    • Sign In
    • State Verified Answer
    • Replies 3 replies
    • Subscribers 60 subscribers
    • Views 3196 views
    • Users 0 members are here
    • Administrator v8i SS4
    • 64bit
    • datasource
    • DatabaseConnecting
    • Application integration
    • 64 bit
    • datasources
    JessieMCS
    Offline JessieMCS over 8 years ago
    Hi
    can i install PWss4 on workgroup not on a domain environment?
    • Sign in to reply
    • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Tue, Apr 14 2015 9:54 AM
      If you are configuring production (testing) environment then it should be on a domain.
      If you just want to test some PW features or play around with some PW parts locally (e.g. settuping VM for yourself) then you can do it on the workgroup.
      Arturas Z
      This is a test
      Answer Verified By: JessieMCS
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • JessieMCS
      0 Offline JessieMCS Wed, Apr 15 2015 1:34 AM in reply to Arturas Zidonis
      Hi Arturas,can you please explain why the PW should be in a domain? thanksJessie
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Wed, Apr 15 2015 4:53 AM in reply to JessieMCS
      Hi Jessie,
      Well, PW Integration Server can be not in a domain but we don't recommend it because you might face some security/access issues later on on your server/network accessing PW datasources. Also Single Sign On won't work.
      Setting up each part of ProjectWise you can see that in PW Implementation Guide it always says: Make sure the computer you are installing on is on a domain. So it's recommended to have PW on a domain and use FQDN names. You can read here more why it is recommended so communities.bentley.com/.../use-fully-qualified-domain-names-for-projectwise-network-configuration
      This is a test
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
