Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum WorkFlow
    • Sign In
    • State Suggested Answer
    • Replies 2 replies
    • Answers 1 answer
    • Subscribers 60 subscribers
    • Views 1639 views
    • Users 0 members are here
    • Workflow
    WorkFlow
    Ergin Akbas
    Offline Ergin Akbas over 8 years ago
    I have a parents folder that has 35000 subfolders. None of these folders currently have a workflow associated with them. Is it possible to assign the work flow to the parent folder and have all of the child folders inherit automatically?
    • Sign in to reply
    • Cancel
    • Scott M. Turner
      0 Scott M. Turner Tue, Apr 28 2015 11:00 PM
      Short answer: No.
      But you may investigate doing it at the database level or with some other form of trickery.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Peter Willmen
      0 Offline Peter Willmen Fri, Jul 17 2015 7:21 AM
      I know this is an old thread but I may be able to help
      I had Bentley Professional Services (PSG) create a function for one of my clients that can change workflows on existing folders and entire folder trees. The function runs as a ProjectWise Customisation (Right-click menu) and also as a command line function.
      The function even works if there are documents in the folders as long as there are matching workflow states. If not the documents are moved to the default (first) state.
      The tool is the 'Propagate Workflow Tool'. I am unable to re-distribute it so you will need to contact your Bentley Account Manager to see if is available to purchase.
      Hope that helps
      Pete.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
