Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum PROS and CONS of Workflows in ProjectWise
    • Sign In
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 3052 views
    • Users 0 members are here
    NATIVIDAD.TAJONERA@STANTEC.COM
    Offline NATIVIDAD.TAJONERA@STANTEC.COM over 8 years ago
     Hi!  May I seek your valuable inputs please on the PROS and CONS of implementing Workflows in ProjectWise.
    Thank you and best regards!
    Vitie
    • Sign in to reply
    • Cancel
    • Scott M. Turner
      Scott M. Turner Sun, Jul 5 2015 7:49 PM
      There are many pros and cons to this, depending on the maturity of the system as well as the teams using the system.
      Workflows can be valuable in that they can be used for control and reporting on the documents in the workflow. Combining workflows with the Rules Engine, version locking and security can result in a well-defined execution environment with many downstream benefits.
      However, there can also be significant challenges in getting project teams that are not used to working like this into a controlled environment. Further to this, if ProjectWise security is not well understood by the admins, incorrectly defining and deploying workflows with security is a very fast way to bring a project to a halt.
      The potential benefits or detriments to your projects really depends on where you are and what your needs are from the system. If your projects are small, fast-paced and come and go quickly, workflows may not be worth-while. However, if you have a need to be able to have as accurate as possible reporting on project deliverables, or need to control many aspects of the document management process, then workflows may be beneficial.
      Some of the downstream benefits also include things like renditioning. Say for example you have a project portal that clients or other users access to get a controlled view of project documents. Workflows can be used to define when a rendition is made, thereby giving you an automated method of making data available at known points along its lifecycle.
      Reporting is also a benefit. Adding metadata to ProjectWise that is used for reporting purposes means that project status reports can also be automated because you know where any given document is in the lifecycle at any given time.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
