Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Linking ProjectWise Document Attributes
    • Sign In
    • State Verified Answer
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 2890 views
    • Users 0 members are here
    Philip Las Gourgues
    Offline Philip Las Gourgues over 8 years ago
    I have an attribute used in the definition of my document code. It's obtained from a pull down list for discipline and adds a single letter to the document code (S - Structural, C - Civil etc). Later in the document attributes which are linked to a Microstation tag set I want to set an attribute to "STRUCTURAL" if S was chosen in the document code, "CIVIL" if C was chosen in the document code etc. Is there an easy way to do this? We're running on an Oracle database.
    Thanks in advance,
    Philip Las Gourgues
    • Sign in to reply
    • Cancel
    Top Replies
    • Peter Willmen
      Offline Peter Willmen Tue, May 26 2015 8:49 AM +1 verified
      Philip,There is a way of doing this by adding a new 'Lookup' environment. As an example this environment (e.g. ENV_LOOKUP) would have 3 fields: CODE, DESC, TYPE You can then add 'documents' (without…
    • Peter Willmen
      +1 Offline Peter Willmen Tue, May 26 2015 8:49 AM
      You can then add 'documents' (without a file attached) into a folder set to this environment to manage the entries.
      e.g. CODE = S, DESC = Structural, TYPE = Discipline
      Then add a new attribute to your document environment with an Update value set to :SELECT DESC FROM ENV_LOOKUP WHERE CODE = '$EDIT#[source attribute]$' AND TYPE = 'Discipline'
      Use your source attribute (with the Discipline code) as a trigger for this new attribute. You will need to update your Tag Set and configure the Attribute Exchange Rules for this to appear in your CAD files.
      I would also recommend using the Lookup environment values to populate your drop-down list to keep the values in sync.
      Hope that is of some help.Peter Willmen
      Answer Verified By: Philip Las Gourgues
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
