Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum PW SS4 on test environment
    • Sign In
    • State Verified Answer
    • Replies 31 replies
    • Subscribers 62 subscribers
    • Views 11787 views
    • Users 0 members are here
    • Database Upgrade
    • Administrator v8i SS4
    • Content Management
    • Application integration
    • 64 bit
    • Configuration
    JessieMCS
    Offline JessieMCS over 8 years ago
    We have an existing PW SS3 on windows 2003 server box and we are planning to upgrade it to PW SS4 on windows 2008 R2 SP1 server. I did manage to install PW SS4 on a test environment using the IMPLEMENTATION GUIDE but I am a bit confuse on the upgrade section.
    can you please show the steps here?
    thanks,
    Jessie
    • Sign in to reply
    • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Wed, May 27 2015 10:17 AM
      Hi JessieMCS,
      So I am assuming you have your database backed up and your new server has PWSS4 Installed.
      1. Connect your database on your database server in a new database (rename it something other than the production)
      2. On the PWSS4 test server create a ODBC connection to the database you just connected (backup database)
      3. Launch a command prompt as a administrator and (change directory to the ProjectWise\Bin folder) c:\program file\bentley\projectwise\bin and type in the following:
         DMSCONV -d ODBC_datasourcename -u ODBC_username -p ODBC_password
      Thia dmsconv.exe utility will start the upgrade process. Once upgrade as been successfully completed in the command prompt window
      4. Launch ProjectWise Administrator and login to complete the schema update (tables updating) it will prompt you to upgrade tables and select 'YES'
      5. Once done you will be upgraded.
      Ranveer
      Answer Verified By: JessieMCS
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • JessieMCS
      0 Offline JessieMCS Wed, May 27 2015 10:29 AM in reply to Ranveer.Basra
      Hi Ranveer,
      just to make it clear. All the steps you have mentioned will be done in the Test environment server (PW SS4)?
      Jessie
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Wed, May 27 2015 10:31 AM in reply to JessieMCS
      That is correct.
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    • JessieMCS
      0 Offline JessieMCS Thu, May 28 2015 3:45 AM in reply to Ranveer.Basra
      Hi Ranveer,
      I tried to restore the database in SQL that I backup from SQL management studio. I got this error " restore failed for server "MCPW". (microsoft.sqlserver.smoextended)
      Additional information:
      system.data.sqlclient.sqlerror: The media set has 2 media families but only 1 are provided.All members must be provided.
      any idea please?
      Jess
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Thu, May 28 2015 6:49 AM in reply to JessieMCS
      Hi JessieMCS,
      Are you restoring from SQL 2000 to SQL 2005? I have seen this before,  when you restored did you restore to a single .bak file or you split the backup to two files. I would backup your database again to a single .bak file. While I cannot support your database however, I can point you to some MSDN support articles that talk about the same error: social.msdn.microsoft.com/.../the-media-set-has-2-media-families-but-only-1-are-provided
      Hope that helps...
      Ranveer
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
