Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum imodel creation time long due to logical sets
    • Sign In
    • State Verified Answer
    • Replies 3 replies
    • Subscribers 60 subscribers
    • Views 1855 views
    • Users 0 members are here
    • projectwise imodel creation
    AndrewH
    Offline AndrewH over 8 years ago
    When creating imodels we have found that although the creation of the dgn.i.dgn file is very quick when publishing as we can see the new file appear very quickly, the file been published then goes through updating the logical sets.  This can take up to 5 mins per file.
    The file been published say file1.dgn has file2.dgn attached with no nesting.  This gives us what we want to see published. file1.dgn and file2.dgn are relatively small in themselves hence the imodels for these two files are relatively small.  The problem seems to be that file2.dgn does have hundreds of references attached and the imodel creation seems to look through all of these files searching for dependencies to update projectwise.
    My question is, is there a way to stop this harvesting of logical sets during the imodel creation?
    TIA
    Andrew
    • Sign in to reply
    • Cancel
    • Todd Combs
      0 Offline Todd Combs Fri, Jun 12 2015 9:56 AM
      Hi Andrew,
      Is iCS or a desktop application being used to publish the i-models? Which application? When the i-model is published outside of ProjectWise is the process relatively quick? I’ll do some research and then get back with you.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Todd Combs
      0 Offline Todd Combs Tue, Jun 16 2015 10:35 AM
      Disable the Logical Set creation process using variable MS_PUBLISHDGN_SKIP_PW_LOGICAL_SET=1, but after creating a package need to run Scan Refs for updating the logical sets for the published files manually.
      Answer Verified By: AndrewH
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    • AndrewH
      0 Offline AndrewH Tue, Jun 16 2015 11:58 PM in reply to Todd Combs
      Hi Todd, That worked for us . Thanks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
