Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Can a member of the Administrator group copy the server path for requesting restores?
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 61 subscribers
    • Views 1656 views
    • Users 0 members are here
    Dean Lyon
    Offline Dean Lyon over 8 years ago
    I have been asked to write a customization that will allow the Admin user to copy the server path, so that they can paste it into the IT restore request form.  Is there a standard way to get this path, or is writing a customizaion needed?
    • Sign in to reply
    • Cancel
    • Scott M. Turner
      0 Scott M. Turner Thu, Jun 18 2015 6:50 PM
      Hi Dean, Could you create a property that stores the value? This would have to be triggered, but in the SQL you could build the string by querying the dms_doc, dms_stor and dms_proj tables.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Fri, Jun 19 2015 2:48 PM in reply to Scott M. Turner
      I could do that, but I really don't want the attribute readable by anyone other than someone in the Adminstrator group. Is there a way to mark the attribute as only viewable by admins?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dan Williams
      0 Offline Dan Williams Fri, Jun 19 2015 3:19 PM in reply to Dean Lyon
      There isn't a way to set permissions on user attributes. Another potential problem is that once this value is set, how would you update it if the storage location was moved by the administrator for one reason or another? Granted, this isn't likely to change, but it could of course.
      I suspect that your "best bet" is to either "educate" your IT folks on how to determine where the file was, or to provide them with a custom tool that only works if the user is an administrator. Or perhaps, generate a custom report from time to time that "maps" a given storage area to a path that they can recognize. I've seen that approach taken by some users, particularly if the number of storage areas isn't too large. The key to this report is making sure that the IT person understands how the dmsXXXX folders relate to the ProjectWise folder ID.
      FWIW, my preference for "restores" is to provide the restored file directly to the user or a ProjectWise Administrator so that they can "restore" it manually. I've seen a few cases where the "IT" folks don't quite understand how ProjectWise works and "restore" a bit too much directly to a storage location and inadvertently create other "issues". Your choice of course.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Mon, Jun 22 2015 9:20 AM in reply to Dan Williams
      I will write a customization for them then. We always have IT restore to a "recovery" directory, then update PW through the UI.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
