Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum need examples of circular reference .. Civil 3D with Project Wise
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 63 subscribers
    • Views 4803 views
    • Users 0 members are here
    • Civil 3D
    • Data Shortcuts
    • circular reference
    Kevin
    Offline Kevin over 8 years ago
    We are battling to use Civil 3D with Project Wise (Civil 3D versions 2013, 2014 and 2015).
    We experience gradual longer waits for drawings to open as more data shortcuts are created and sometimes the data shortcuts become broken (reason unknown).
    Some guides indicate that the problem could be circular referencing.
    Maybe the process we used for data shortcuts on the "network" cannot be used with Project Wise - ? Is that true?
    We never experienced this problem with data shortcuts on the network (from years 2008 to 2014).
    Is the following maybe a circular reference?
    • Start a Civil 3D data shortcuts project (CivilDSProj ZIP file)
    • Create existing ground surface DWG (A.DWG)
    • Create surface in A.DWG and add data shortcut to the CivilDSProj
    • Create road centre-line DWG (B.DWG)
    • Create alignment in B.DWG and add data shortcut to the CivilDSProj
    • Create a road design DWG (C.DWG)
    • Add data references (existing ground surface and road alignment) to C.DWG
    • Create a road top surface in C.DWG and add data shortcut to the CivilSProj
    If this is not a Civil 3D circular reference then what is? Please provide an example.
    Dependency Viewer of C.DWG:
    Thanks for your patience,
    Thx for reading,
    Kevin.
    • Sign in to reply
    • Cancel
    • Paul Patterson
      0 Paul Patterson Mon, Jul 27 2015 1:10 PM
      Kevin,
      Our initial way of thinking was to just have one datashortcuts project per job.. but the volume of associations this would create within ProjectWise over time was staggering. This obviously led to a lengthy time to copy the data out of the data center, and down to the local PC's.. (cache servers helped here..)
      I can say through our experiences, we've found that dividing up the datashortcuts in a logical manner, has greatly improved the performance. Whether this be by area, segment, contract #, etc depends on your project.
      Additionally, as for shortcuts mysteriously disappearing, we've encountered similar. In our case, we found that this was largely due to poor design management.. the designers were renaming source model files.. renaming objects.. deleting objects.. etc. Never a dull moment.
      We've learned (the hard way), that it's crucial to have a proper file / object naming convention, as well as to lay out a model matrix upfront. Which, to be fair, is good practice anyways.
      Looking forward to your findings on the circular references...
      Paul
      Answer Verified By: Kevin
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • spear
      0 Offline spear Tue, Jul 23 2019 5:07 PM in reply to Paul Patterson
      Paul, how many references would you recommend as the threshold?
      We're seeing performance issues with projects I wouldn't consider multiple DS projects for.. ie. source drawings consist of  5 Alignments in one file, 1 corridor file, 1 grading file, and 1 existing ground file. They are land development sized sites as well, not long highways.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Paul Patterson
      0 Offline Paul Patterson Fri, Jul 26 2019 1:14 PM in reply to spear
      I think there's many variables that would contribute.. there's no hard number..
      What you've suggested seems reasonable..
      Have you checked the dependency viewer?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Paul Patterson
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
