Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum need examples of circular reference .. Civil 3D with Project Wise
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 62 subscribers
    • Views 4753 views
    • Users 0 members are here
    • Civil 3D
    • Data Shortcuts
    • circular reference
    Kevin
    Offline Kevin over 8 years ago
    We are battling to use Civil 3D with Project Wise (Civil 3D versions 2013, 2014 and 2015).
    We experience gradual longer waits for drawings to open as more data shortcuts are created and sometimes the data shortcuts become broken (reason unknown).
    Some guides indicate that the problem could be circular referencing.
    Maybe the process we used for data shortcuts on the "network" cannot be used with Project Wise - ? Is that true?
    We never experienced this problem with data shortcuts on the network (from years 2008 to 2014).
    Is the following maybe a circular reference?
    • Start a Civil 3D data shortcuts project (CivilDSProj ZIP file)
    • Create existing ground surface DWG (A.DWG)
    • Create surface in A.DWG and add data shortcut to the CivilDSProj
    • Create road centre-line DWG (B.DWG)
    • Create alignment in B.DWG and add data shortcut to the CivilDSProj
    • Create a road design DWG (C.DWG)
    • Add data references (existing ground surface and road alignment) to C.DWG
    • Create a road top surface in C.DWG and add data shortcut to the CivilSProj
    If this is not a Civil 3D circular reference then what is? Please provide an example.
    Dependency Viewer of C.DWG:
    Thanks for your patience,
    Thx for reading,
    Kevin.
    • Sign in to reply
    • Cancel
    • Paul Patterson
      0 Offline Paul Patterson Fri, Jul 26 2019 1:14 PM in reply to spear
      I think there's many variables that would contribute.. there's no hard number..
      What you've suggested seems reasonable..
      Have you checked the dependency viewer?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
