Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Cannot Detach a model from managed model
    • Sign In
    • Replies 15 replies
    • Subscribers 67 subscribers
    • Views 20522 views
    • Users 0 members are here
    • Cannot Detach a model from managed model
    rblair
    Offline rblair over 8 years ago
    MS version 08.11.09.714
    I get an error when trying to simply detach a reference file.
    "You cannot detach a model from a managed model. The operation is cancelled."
    Is this a known bug with this new version of Microstation? I had this version installed this week and previously never seen this error message.
    • Sign in to reply
    • Cancel
    Top Replies
    • rblair
      Offline rblair Wed, Nov 11 2015 1:52 PM in reply to rblair +1
      I found a work-around. If you have Inroads SS2 still on your machine, open Inroads SS2 through your start menu. This clears the association of Microstation to Inroads SS4 and changes the app switch from…
    • Jon Summers
      Offline Jon Summers Wed, Jul 29 2015 3:59 PM
      Are you using any other application with MicroStation?  For example, ProjectWise?
      Regards, Jon Summers
      LA Solutions
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • rblair
      Offline rblair Wed, Jul 29 2015 4:45 PM
      Yes, I have ProjectWise open, and I opened the Microstation file through ProjectWise. This is something I’ve done for years without problems in previous Microstation versions though. I had 08.11.09.714 installed last week because that is the version compatible with Openroads (Inroads 08.11.09.845)
      • Cancel
      • Sign in to reply
      • Cancel
    • Maria Garcia
      Maria Garcia Mon, Aug 17 2015 11:06 AM in reply to rblair
      Hi Ryan,
      Could you please upload the dgn file together with any of the reference files you can not detach for testing purpose?
      I have installed MicroStation 08.11.09.714 and I can not reproduce the issue.
      Maria
      • Cancel
      • Sign in to reply
      • Cancel
    • Jacquelyn Pettus
      Offline Jacquelyn Pettus Mon, Aug 17 2015 5:18 PM
      Take a look at the wiki below for the answer to your question:
      http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/23260.unable-to-detach-reference-file-in-microstation
      • Cancel
      • Sign in to reply
      • Cancel
    • rblair
      Offline rblair Wed, Aug 19 2015 10:27 AM in reply to Jacquelyn Pettus
      The solution posted may work but it isn’t practical. I shouldn’t have to load Openroads in order to detach a simple dgn file that wasn’t attached through Openroads. I should be able to do it through Microstation. Furthermore, if I have to open the file with Openroads, it says there’s obsolete civil data found and asks to upgrade the data.
      When detaching a dgn, Microstation should have the capability to tell whether or not there’s civil data dependencies or not. If there is civil data dependencies, then a warning message makes sense, but not if there’s no civil data dependencies. To disable detaching a reference from basic Microstation whether or not there’s civil data dependencies is not acceptable.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
