Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Disappearing Global Searches?
    • Sign In
    • State Verified Answer
    • Replies 7 replies
    • Subscribers 61 subscribers
    • Views 4525 views
    • Users 0 members are here
    • Saved Searces
    • ProjectWise
    Paul Patterson
    Paul Patterson over 8 years ago
    Afternoon everyone,
    I'm finally putting the effort into creating boat loads of saved searches in the datasources, and in our project template.
    I have nested saved searches.. essentially a parent category, and when expanded, shows multiple other searches.
    For some reason.. the nested (or sub-searches?), won't show, unless I create a dummy search... and then, they'll magically appear. Quite annoying.
    Example..
    "By Document Status" and "By Rec'd Date" appear to have no nested sub-searches..
    But.. create a "Dummy Saved Search" in each of them...and blammo.. up comes all of my nested searches.
    Has anyone encountered this before? I'd prefer not to have to leave dummy saved searches in there just to expose the others.
    Paul Patterson
    • Sign in to reply
    • Cancel
    Top Replies
    • Matthew Saxon
      Offline Matthew Saxon Mon, Apr 1 2019 4:20 AM in reply to Arturas Zidonis +1
      This still happens.
    • Scott M. Turner
      0 Scott M. Turner Thu, Aug 20 2015 11:21 PM
      Hi Paul, I ran into the same thing on a recent project I set up. IIRC renaming (even to the same name) the searches took care of it, but I agree it is a pain.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Fri, Aug 21 2015 4:55 AM
      Hi Paul,
      Do you know how this happens/how to reproduce that some nested saved searches are not being shown and only appears once 'dummy' saved search is created?
      Arturas Zidonis
      This is a test
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Fri, Aug 21 2015 5:18 AM in reply to Arturas Zidonis
      Paul,
      I've found more information about this issue. It seems that it's a memory issue and its not fixed yet. Users have to select refresh to see all the searches after they open ProjectWise the first time., so maybe you don't need to creat 'dummy' searches to see all those searches that are not showing up.
      This is a test
      Answer Verified By: Paul Patterson
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Paul Patterson
      0 Paul Patterson Fri, Aug 21 2015 9:22 AM in reply to Arturas Zidonis
      Arturas,
      Thanks for this.
      Unfortunately, trying to communicate to the thousands of users we have that they need to refresh the node isn't terribly feasible.. nor sustainable :)
      Oddly, unsure why when I leave a dummy saved search in there, the nodes show just fine. In the meantime, I'll simply leave a null search with "_" as the name..
      If you can, please attach me to any CR/SR that exists for this!
      Thanks again for the info.
      Paul Patterson
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Paul Patterson
      0 Paul Patterson Fri, Aug 21 2015 9:23 AM in reply to Scott M. Turner
      Hi Scott,
      I gave the rename idea a whirl, didn't fly in our environment. I've resorted to simply leaving a null search named "_" in the disappearing nodes. Not terribly elegant, but will have to do for now.
      Thanks for the reply.
      Paul Patterson
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
