New integration server - old links cannot be resolved
Hi everyone.
We have recently moved our ProjectWise integration server to a new clustered environment. This resulted in a slightly changed format of our ProjectWise Explorer links (the integration server part in the link is now replaced with the dns for the cluster).
This means old links will no longer resolve. On our internal network we have solved it by setting up a dns with the old integration server name pointing to the cluster. But we haven't found a solution for external users accessing ProjectWise via our Gateway server.
Has anyone else previously been in a similar scenario, where you moved ProjectWise to a new Integration server? And did you find a solution on how to resolve old ProjectWise Explorer links accessed on the external network?
Thanks.
Morten Stougaard
