Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Titleblock Intetgration and AECOsim Building Designer (SELECTseries 5)
    • Sign In
    • State Suggested Answer
    • Replies 3 replies
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 2094 views
    • Users 0 members are here
    • Titleblock Integration
    • AECOsim
    • ProjectWise
    Bob Hanson
    Offline Bob Hanson over 7 years ago
    A user uses AECOsim exclusively.  He stated that Titleblock Integration does not work.  I have opened the file with AECOsim and confirmed.  I open the same file with MicroStation and Titleblock Integration works fine.  Does anyone know if Titleblock Integration works with AECOsim?
    ProjectWise Integration Server and Client - v08.11.11.590
    AECOsim Building Designer (SELECTseries 5) v08.11.09.747
    Thanks in advance.
    • Sign in to reply
    • Cancel
    • JackiS
      0 Offline JackiS Wed, Oct 7 2015 6:30 PM
      Bob: I would call in and speak with someone in the building group about this. They can confirm integration with titleblock.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robert DiMauro
      0 Offline Robert DiMauro Mon, Oct 19 2015 9:03 AM
      There was a "similar" issue with someone using Plant products. As far as I know this is not specific to AECOsim. It may be PC specific concerning a file on the machine and title block.ma. Do you have a file called tbldr.ma or similar? Our best advice is to uninstall everything and run a registry cleaner several times, reboot and reinstall. Make sure that you don't have any lingering prior versions of applications that were installed/uninstalled and remove what you don't need and no longer use.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Christian Mittermeier
      0 Offline Christian Mittermeier Fri, Oct 30 2015 4:15 AM
      Yes it works.
      We use both, MicroStation and AECOsim with  ProjectWise and Titleblock Integration works quite well.
      For the exchange we use a MCMTB.ma.
      The only problem with titleblock exchange we had, whether in MicroStation or in AECOsim, was when the MCMTB.ma was missing in the specific program path.
      WIN7-64bit (German)
      ProjectWise SS4 08.11.11.590 English
      MicroStation SS3 08.11.09.459 English
      AECOsim SS6 08.11.09.829 English
      Dataset NM 08.11.09.822 customized
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
