Is it possible to assign a PW Project property to a MicroStation workspace variable?
We would like to produce a dymanic workspace setup which adapts the workspaces loaded based upon values set in a PW project property.
If tried a 'string' assignment syntax of  $(PROJECT#PROJECT_Code_<property name>) but it does not work.
Thanks for any help you can provide.
