Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum AutoCAD Integration in ProjectWise CONNECT Edition?
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 62 subscribers
    • Views 7358 views
    • Users 0 members are here
    • CONNECT Edition
    • AutoCAD 2015
    • ProjectWise
    jcallicott
    Offline jcallicott over 7 years ago
    Greetings,
    We recently made the move to the Autodesk 2015 family of products and as a result needed to deploy PW integration for those programs.  However, we are on the 8.11.11.574 client.  The 590 client (or later) is required for the 2015 integration to work.
    I saw that the CONNECT edition was recently made available.  I figured: why bother with 590, when CONNECT is now out?  So I downloaded it, tested it, and it's running great... until I try to install 2015 integration.  It claims I need the 590 or later client installed!
    So I presume the integration for AutoCAD will be re-released for CONNECT soon, since the 2015 integration installer doesn't register PW Explorer CONNECT Edition as a later version.  Right now, I have a lot of PCS to upgrade the client on so they can have 2015 integration.  My preference is not to have to upgrade them twice (first to 590, then to CONNECT as those programs on the Bentley side roll out).
    Thoughts?
    • Sign in to reply
    • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Thu, Sep 24 2015 10:08 AM
      The CONNECT edition Integration Module for AutoCAD 2014, 2015, and 2016 was released September 23, 2015 and can be downloaded through the fulfillment center. The version number is 08.11.11.851
      Answer Verified By: jcallicott
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • JackiS
      0 Offline JackiS Thu, Sep 24 2015 4:04 PM in reply to Dana Guthrie
      Also released were the integration modules for Revit 2014, Revit 2015, Revit 2016 and Office 2013/364. The integration modules for AutoCAD do support advanced Civil 3D integration.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • jcallicott
      0 Offline jcallicott Wed, Oct 7 2015 2:14 PM
      Dana, Jacki,
      This is exactly what I needed. looks like I asked just as Bentley was getting ready to roll out this solution.
      Thanks!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Louie.N
      0 Offline Louie.N Thu, Apr 20 2017 12:08 PM in reply to Dana Guthrie
      Dana, I have gone to the Fulfillment center and found the modules... but they are all 32-bit I'm (being forced) running Civil 3D 2016 64-bit with ProjectWise Explorer Version 10.00.01.67 - Commercial Release. Is there a magic trick to finding the 64-bit versions?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Molly Watts
      0 Offline Molly Watts Thu, Apr 20 2017 12:25 PM in reply to Louie.N
      Louie, you can ignore the 32 bit terminology in the naming...once you download and run the installer, it will install the appropriate version for your operating system.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
