Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Windows Server 2012 R2 for SQL Server and Design Integration Server
    • Sign In
    • State Suggested Answer
    • Replies 5 replies
    • Answers 1 answer
    • Subscribers 60 subscribers
    • Views 3589 views
    • Users 0 members are here
    Richard Griffin
    Offline Richard Griffin over 7 years ago
    Can someone please confirm whether Windows Server 2012 R2 (as opposed to just Windows Server 2012) is a supported operating system for use with both the SQL Server and the Design Integration Server?
    Many thanks.
    • Sign in to reply
    • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Fri, Oct 2 2015 1:14 AM
      Hi Richard,
      Windows Server 2012 R2 is not supported with ProjectWise Design Integration Server yet. Latest ProjectWise Design Integration Server release (10.0.0.20) is supported with these OS:
      Windows Server 2008 SP2, Standard/Enterprise Editions (64-bit)
      Windows Server 2008 R2 SP1, Standard/Enterprise Editions (64-bit)
      Windows Server 2012, Standard/Datacenter Editions (64-bit)
      AZ.
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Richard Griffin
      0 Offline Richard Griffin Wed, Oct 7 2015 10:28 AM in reply to Arturas Zidonis
      Thanks for reply Arturas. Can you also confirm for the SQL Server please?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • JackiS
      0 Offline JackiS Wed, Oct 7 2015 1:21 PM in reply to Richard Griffin
      Richard:
      The Supported Databases are listed below (which also can be found in the readme).  The readme can also be found in the software download in Fulfillment Center as well as in the files section of this community.  http://communities.bentley.com/products/projectwise/content_management/m/mediagallery/271121
      If you hover of the link or select the download button next to the subject title it will download.
      ProjectWise Design Integration Server supports:
      Microsoft SQL Server 2012 SP2
      Microsoft SQL Server 2008 R2 SP3
      Oracle Database 11g (11.2.0.4)
      ProjectWise Orchestration Framework Service supports:
      Microsoft SQL Server 2012, Express Edition
      Microsoft SQL Server 2008 R2 SP2 or later, Express Edition (delivered with ProjectWise Server Setups)
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gary Turner
      0 Offline Gary Turner Thu, Oct 8 2015 10:20 AM in reply to JackiS
      Could you please confirm if a server running Windows Server 2012r2 with SQL 2012 would be supported? The server would only be hosting Projectwise databases and no Projectwise software so should be okay?
      Also when will Windows 2012 r2 be supported properly by Bentley? This has been available for over two years now and is now the server operating system of choice in most organisations. Surely as Connect has only just been released it should of been built to support current mainstream operating systems.
      Thanks.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Fri, Oct 9 2015 1:13 AM in reply to Gary Turner
      It might work without any issues having only databases on Windows Server 2012r2. However this configuration haven't been tested and is not certified, so it means it's not supported.
      Windows 2012 r2 should be supported in ProjectWise CONNECT edition release 2.
      This is a test
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
