Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum open more than one office document / file
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 3682 views
    • Users 0 members are here
    • more than one
    • office
    • open
    • project wise explorer
    Kevin
    Offline Kevin over 7 years ago
    Over the past two weeks users have reported problems in opening more than one document.
    • Opened using Project Wise Explorer
    • One user was Excel 2010
    • The other was Word 2010
    Both users encountered a similar problem.
    The first file opens correctly.
    After clicking Open on the second Document, the second file does not open with the software app (Word or Excel).
    This is probably a know problem - correct? And there is already a thread with details on "how to solve" - correct?
    Maybe this was a known problem with Office 2010 integration that has been corrected with the Office 2013 integration - yes?
    Thank You.
    Kevin.
    • Sign in to reply
    • Cancel
    • mantas.nauseda
      0 mantas.nauseda Tue, Feb 2 2016 12:05 AM
      Hi Kevin,
      There is a quite good feature in ProjectWise that allows you to open the document in new instance of any application. To do that you can open first document as you would normally do, but when you want to open another document you pres and hold Shift key on the keyboard and then double click (or use other method) to open the document. This should start a new instance of the associated application and it should also open the document.
      Hope this helps,
      Mantas
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
