Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Export / Import (Excel) Tool
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 61 subscribers
    • Views 4046 views
    • Users 0 members are here
    Paul Patterson
    Paul Patterson over 7 years ago
    All,
    I'm trying to export a set of documents, which have versions using the "export to excel" tool.
    When I highlight a set of documents, that do not have versions, I'm able to add them to the export list.. and subsequently, they are pre-populated to the export list when I choose to export to excel.
    Oddly, when I select files that have versions, even with the versions unselected, when I export to excel, no files are "checked".. causing me to manually select them.
    With many files, in different subfolders, this is going to be a painful exercise.
    Anyone experienced this in the past?
    Paul
    • Sign in to reply
    • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Wed, Dec 9 2015 1:05 PM
      Hello Paul. I am not able to reproduce the problem. What version of ProjectWise explorer and export excel tool are you using?  I am using 08.11.11.590
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Paul Patterson
      0 Paul Patterson Thu, Dec 10 2015 3:08 PM in reply to Dana Guthrie
      Hi Dana,
      this happens both on the 10.x.x.x version, and 08.11.11.590! I suspect the export tool is 08.11.11.111..
      Glad to share a screen with you ..
      Paul
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Scott M. Turner
      0 Scott M. Turner Thu, Dec 10 2015 4:17 PM
      I've seen this too, Paul.
      The only way I was able to get around it reliably was to make sure to use the pull down menu and not the right-click menu when adding to the export list. This is using 590 by the way.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
