Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Using Command line Arguments in Workspace Profiles for MicroStation Connect
    • Sign In
    • State Verified Answer
    • Replies 4 replies
    • Subscribers 59 subscribers
    • Views 3590 views
    • Users 0 members are here
    • Workspace Profiles
    • MicroStation Connect
    • COMMAND LINE ARGUMENTS
    Gary Mansager
    Offline Gary Mansager over 7 years ago
    Can someone provide a working example of using Workspace Profiles within MicroStation CONNECT Edition? We can't seem to get the -wr or -ww (or -WW -WK) arguments to function. the only argument we can get to work is -debug (thank goodness!)
    • Sign in to reply
    • Cancel
    • Gary Mansager
      0 Offline Gary Mansager Thu, Jan 21 2016 11:39 AM
      Upon further investigation, the only reason -debug worked is because it was applied through the program associations!
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Vickie Ramsey
      0 Offline Vickie Ramsey Thu, Jan 21 2016 2:46 PM
      Make sure you are using ProjectWise Design Integration CONNECT Edition, ProjectWise V8i is not compatible.
      I use -wk (Workspace folder name) -ww (Workset Folder name)
      Put it in quotes if there are any spaces.
      Answer Verified By: Gary Mansager
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Gary Mansager
      0 Offline Gary Mansager Fri, Jan 22 2016 9:06 AM in reply to Vickie Ramsey
      Thanks Vickie. Makes sense.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • dgbitts
      0 Offline dgbitts Thu, Mar 19 2020 8:43 AM in reply to Vickie Ramsey
      I am trying to get Microstation CONNECT Edition to open dgns out of PW Explorer CONNECT without using a workset. The folders have a Managed Workspace configuration for AECOsim Building Designer CONNECT. Some users use AECOsim and others use Microstation CONNECT. I need Microstation CONNECT to open the file without it going to the open file screen and asking the user to specify a workset. I want to use the -ww switch in the Microstation Program association command line but I'm not sure whether to specify -ww=NONE or some numeric code.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
