ProjectWise Explorer V8i (SS4) 08.11.11.590
I created a Document Code with three attributes: TYPE, AREA, SERIALNUM (max 6 chars with leading zeros).
When I create a document with TYPE 'DWG', AREA 'ENG' and generate a serial number I get document code DWG-ENG-000001.
The document name that is assigned to the document is DWG-ENG-1.
How do I get the drawing name to reflect the document code correctly?
Answer Verified By: JSONS
