Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum sheet set keeps opening/checking out
    • Sign In
    • State Suggested Answer
    • Replies 11 replies
    • Answers 2 answers
    • Subscribers 62 subscribers
    • Views 6570 views
    • Users 0 members are here
    • SSM
    • sheetset
    • ProjectWise
    • dst
    spear
    Offline spear over 7 years ago
    We are having a serious issue with SSM in projectwise. We want to stop the dst file from opening when we check out a drawing that's contained in it. It's causing issues because people don't realize they are checking out a file so they don't check it back in and others think they are making edits to a read only version and are wondering why others don't see they're changes.
    Prior to projectwise, we could just set the autocad variables sslocate and ssmautoopen to 0. However those variable don't have any impact when projectwise is involved.
    My DMS variables are as follows...
    REFTIME 5
    REFMODE 1
    REFMISSINGMODE 1
    REFPATH 0
    REFRELOADMODE 0
    PLOTTINGMODE 1
    ATTACHMODE 1
    SHOWSFM 1
    SHOWMISSINGSHAPES 1
    ETRANSMITMODE 1
    SHEETSETMODE 1
    Could somebody please help?
    • Sign in to reply
    • Cancel
    • Vickie Ramsey
      0 Offline Vickie Ramsey Thu, Mar 17 2016 9:09 AM
      As you have described, the default behavior in ProjectWise when opening a sheet set member is to check out the Sheet Set file.
      It is a different workflow than most AutoCAD users expect.
      Once the file is open you can switch to ProjectWise and check the file in. Once everyone understands that they need to check the file out make the changes and check the file back in. Things will smooth out.
      Making sure that ProjectWise displays who has the file checked out will help communication.
       An Enhancement request has been filed asking that this behavior be investigated and changed if possible to be more like the native AutoCAD behavior.
      Meanwhile there are a couple of tools you can enable that may make things better for your users:
      • They can user the Local Document Organizer to manage their copy outs and to check out / in files.
      • You can turn on the User Setting "Show Local Document Organizer on Log Out" located in the User Interface category. This will show users if they are leaving any files in a checked out status.
      • You can turn on the User Setting "Show Select References dialog" located in the User Interface category. This will show users what files are being copied out and which are being checked out as they open a file.
      Hopefully some of these suggestions will help.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • spear
      0 Offline spear Thu, Mar 17 2016 7:13 PM in reply to Vickie Ramsey
      That's disappointing. Hopefully the enhancement request process doesn't take long.
      I understand that with some diligence, we should be able to work around this drawback but the fact is it's been almost 2years now and most users still don't get it and from previous experience bad habits will prevail.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • David Harrison
      0 Offline David Harrison Thu, Sep 1 2016 10:53 AM in reply to spear
      I am experiencing this also and it is really annoying. Why would it be the default behavior when 99% of the time when someone opens a drawing they are NOT making changes to the sheet set file? And just about every time we open/close a drawing we need to also check in or free the sheet set file. This is a huge time waster and the workarounds they provided do not remedy that.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Phil Conard
      0 Offline Phil Conard Thu, Sep 1 2016 2:49 PM in reply to David Harrison
      This is fixed in the latest ProjectWise Explorer client.  A new DMSSET variable was introduced called shared sheet set.  When this is set to 1, the dst file will not be checked out until an editable command is invoked (create sheet, rename sheet, etc).  The latest PW Client install is compatible with all of the Select Series servers.  Please see this link for more about the latest ProjectWise Explorer.
      Phil
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Phil Conard
      0 Offline Phil Conard Thu, Sep 1 2016 2:52 PM
      Hi Spear,
      The latest ProjectWise Explorer client now also respects the SSMAUTOPEN and SSLOCATE variables.  For more about the latest ProjectWise Explorer client, please see this post
      Phil
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
