Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise CONNECT Edition - client silent install
    • Sign In
    • State Not Answered
    • +2 person also asked this people also asked this
    • Replies 17 replies
    • Subscribers 65 subscribers
    • Views 18930 views
    • Users 0 members are here
    • administrator automation
    • COMMAND LINE ARGUMENTS
    David Nelson
    Offline David Nelson over 7 years ago
    How do we install version 10.0 (latest release) of ProjectWise Explorer in silent/unattended mode, in Windows 7 and 10?
    I tried "Setup_ProjectWisex64_10.00.01.25.exe /?" to look for command line help, but nothing happens when I run that.
    Also is there any way around the refusal to install when a "system reboot is pending"? That really throws a wrench into the ability to deploy this software unattended or widely.
    • Sign in to reply
    • Cancel
    Top Replies
    • David Nelson
      Offline David Nelson Tue, Jan 2 2018 2:17 PM in reply to Dana Guthrie +1
      We have been successful with silent installation of ProjectWise Client 10.00.02.265. However, the next version 10.00.02.320 silent install option does not work. Instead, the ProjectWise installation…
    • Adam Morris
      0 Offline Adam Morris Wed, Mar 16 2016 11:48 AM
      I would like to know this as well. We are using SCCM to deploy the Projectwise Connect Client and would need to do this silently as well.
      I also got the system reboot is pending and it would not install without a reboot.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Wed, Mar 16 2016 3:11 PM
      The Connect Edition or ProjectWise Explore does not provide an .msi package anymore, but has an .exe that bundles all the ProjectWise Connect Edition features as well as the Bentley Connection Client.
      Parameters that are used to set a specific action for installation:
      • -q, -quiet, -s, -silent = silent install
      • -uninstall = uninstall
      • -repair = repair (or install if not installed)
      Parameters that are used to select specific packages for installation:
      • ADDLOCAL : Add specific features or All features
      • REMOVE : Remove or Do not install Features
      • REINSTALL
      Available packages (Case-sensitive):
      • DgnNavigatorControlAx
      • AutoCAD2014
      • AutoCAD2015
      • AutoCAD2016
      • Office2013
      • InDesignCC2015
      • InDesignCS6
      • Revit2014
      • Revit2015 (only available in x64 setup)
      • Revit2016 (only available in x64 setup)
      Example:
      Install ProjectWise Explore silently with the DgnNavigator and ProjectWise integration for Microsoft Office 2013
      Setup_ProjectWisex64_10.00.01.25.exe -s ADDLOCAL=DgnNavigatorControlAx,Office2013
      Install all features for ProjectWise Explore Connection edition
      Setup_ProjectWisex64_10.00.01.25.exe -s ADDLOCAL=ALL
      Install all, except DgnNavigator and ProjectWise integration for Microsoft Office 2013.
      Setup_ProjectWisex64_10.00.01.25.exe -s ADDLOCAL=ALL REMOVE=DgnNavigatorControlAx,Office2013
      There is a Technote in the making and should be posted soon with more information. I will update this post with a link to the technote when it is posted.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Adam Morris
      0 Offline Adam Morris Wed, Mar 16 2016 3:30 PM in reply to Dana Guthrie
      This worked great. Another thing I wanted to know is if there is a way to disable Connection updates from showing to users? Our users don't have admin rights and don't want them constantly trying to update something that they cannot update and in turn calling us about it.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Fri, Mar 18 2016 11:40 AM
      The technote I mentioned earlier has been posted.
      communities.bentley.com/.../27308.projectwise-design-integration-connect-edition-client-unattended-install
      To answer the question about the "system reboot is pending" issue... Bentley is aware of the issue, but at this time there is not a workaround.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Fri, Mar 18 2016 11:44 AM in reply to Adam Morris
      If you right click on the CONNECTION client Icon in the system tray and choose "Update" it brings up a GUI and checks for updates. In the right hand corner of this GUI is a link called "Settings". In the Settings page you are able to set the "Critical Update Settings" to "Do not check for updates".
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
