Projectwise Publishing DWG files via DCS with title block update
We have DGN publishing to PDF via the DCS server running for some time.
Now we are trying to add support for AutoCad DWG files,
We have the Projectwise title block integration in AutoCad 2016 working
We have publishing running for dwg's and  a PDF is produced with the correct print area/selection.
However the Projectwise attributes are changed in our workflow just before publishing,
 for DGN's the title block is updated by the dcs server during printing
For DWG's this does not happen is there a way to configure the same update during publishing so the title block shows the last changes.
