I have been playing with MicroStation CONNECT and studying ProjectWise CONNECT.
While Bentley has changed names and operability of its MicroStation configuration levels (organization, workspaces, worksets, roles), it appears that Bentley has not made any changes to the managed workspace levels (site, project, discipline, etc.) in ProjectWise .
Is Bentley formally defining any parallels between MicroStation CONNECT configuration levels and the ProjectWise CONNECT managed workspace levels? Will the managed workspace levels change names or operability in ProjectWise CONNECT in future releases? Does the MicroStation CONNECT WorkSpaceSetup.cfg file have any impact on ProjectWise managed workspace CSB's? Will MicroStation users experience anything in the interface that says "WorkSpace" or "WorkSet" when working in the ProjectWise CONNECT environment?
are worksets supported in ProjectWise CONNECT with MicroStation Update 4 in a managed workspace environment? Meaning, can the dgnws file reside in the PW project structure and function correctly? Figured I would ask before spending time trying to get it to run. I have most everything else at the moment running but from what I am reading, a workset is required to use the Sheet Index Tools.
