Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Attributes in the admin console
    • Sign In
    • State Verified Answer
    • Replies 5 replies
    • Answers 1 answer
    • Subscribers 63 subscribers
    • Views 2097 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin over 7 years ago
    I create a new attributes in the admin console under an environment.
    At the creation we can define column attributes
    • The type
    • The length
    • Enable "allow nulls"
    How can we edit those Column Properties once they are create?
    • Sign in to reply
    • Cancel
    • Stephen Herrick
      0 Offline Stephen Herrick Thu, Jul 21 2016 11:09 AM
      Once you have created them, you cannot edit them. Don't try to do it via SQL, easiest thing is to delete them and build a new one. If you delete the attribute, of course all of the data is gone. Contact BPS if you need them changed
      SH
      Answer Verified By: aaparker
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • aaparker
      0 Offline aaparker Thu, Jul 21 2016 3:58 PM in reply to Stephen Herrick
      Luc,
      Stephen is correct, you need to create a new attribute with the correct length and type and then have your dba simply copy the content from the old attribute to the new one. Then you are free to delete the old attribute.
      This is a test
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Molly Watts
      0 Offline Molly Watts Thu, Jul 21 2016 5:02 PM in reply to aaparker
      If the old attribute is already used in the datasource, here is a way to copy data over to the new attribute: communities.bentley.com/.../have-you-outgrown-your-environment-four-steps-to-free-your-data
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Fri, Jul 22 2016 10:39 AM in reply to Molly Watts
      Thank you Molly
      That help
      Side question, is there a place where I could have more info about the $EDIT#xxxx$ ( not sure how they are call).
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Thu, Sep 22 2016 5:26 PM in reply to Molly Watts
      Never mind....
      As always  I need to ask to find the answer :-) I need to use System variable
      Hi Molly
      I finally get some time to explorer this link
      I try to follow the instructions and use $EDIT#Too_Small$
      However when the new attributes get update, instead of seeing the value of the old attibutes being transfer, i saw the formula $EDIT#Too_Small$
      Not sure what i have done wrong, any chance you could give me a quick tips?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
