Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Issues with Civil 3D (2014 and 2016) integration after installing CE 10.0.1.67
    • Sign In
    • State Suggested Answer
    • Replies 5 replies
    • Answers 1 answer
    • Subscribers 62 subscribers
    • Views 2715 views
    • Users 0 members are here
    • ProjectWise AutoCAD C3D Integration
    • C3D 2014
    • 64 bit
    • C3D 2016
    Brandon Turcotte
    Offline Brandon Turcotte over 7 years ago
    I have installed Projectwise Connect edition 10.0.1.67 this morning.
    Both Civil 3D 2014 and 2016 return 'Customization file load failed. File not found' notices for  _RIBBON and _REFRESHSHORTCUTNODE.
    Have tried reinstall on PW components, repair of AutoCad installs, etc.  Not change in message.  Looking for any advice on how to proceed.
    • Sign in to reply
    • Cancel
    • Marty.Nickel
      0 Offline Marty.Nickel Mon, Aug 8 2016 11:02 AM
      Where did you get this installer from? This build is not on selectservices for download.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Louie.N
      0 Offline Louie.N Tue, Jan 31 2017 6:32 AM in reply to Marty.Nickel
      I have the exact same issue... And the Installer for PW came from Bentley
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brandon Turcotte
      0 Offline Brandon Turcotte Tue, Jan 31 2017 8:00 AM in reply to Louie.N
      Louie, our testing showed that having both 2014 and 2016 installed at the same time seems to cause this. Once we uninstalled 2014, and reinstalled 2016 it worked again. Inconvenient if you need the older version for compatibility.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Louie.N
      0 Offline Louie.N Tue, Jan 31 2017 8:20 AM in reply to Brandon Turcotte
      Thanks Brandon but unfortunately life isn't that simple... We have clients that insist we stay with Civil3D 2014... Why can't everybody just use OpenRoads
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Phil Conard
      0 Offline Phil Conard Tue, Jan 31 2017 5:28 PM in reply to Louie.N
      Hi Louie.N,
      This was discovered as a bug and we have a workaround. Copy all of the files that are in C:\ProgramData\Bentley\ProjectWise\08.11\AutoCAD\support\en to C:\ProgramData\Bentley\ProjectWise\10.00\AutoCAD\support\en. If there are any files that windows tells you are duplicated, just ignore copying those over.
      Phil
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
