Quick question regarding something that is causing some confusion.
Currently I am in the process of upgrading some of our existing servers to newer OS - 2003 R2 (32bit) to 2008 R2 (64bit).
The existing servers have WMI performance counters for the ProjectWise server component giving information on sessions, connections, DB connection, exceptions, etc.
After installing the ProjectWise server software on the server (SS2), there are no performance counters also installed. Is there a particular method or are the software components for this located elsewhere?
Thanks.
The batch file provided in that link is actually just to start collecting the data... shouldn't be needed to add the counters to the server itself. what version of PW and what OS is it running on?
