Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Server (DMSKRNL) WMI performance counters
    • Sign In
    • State Suggested Answer
    • Replies 9 replies
    • Answers 3 answers
    • Subscribers 61 subscribers
    • Views 4323 views
    • Users 0 members are here
    • WMI ProjectWise server counter
    Vincent Steadman
    Offline Vincent Steadman over 7 years ago
    Quick question regarding something that is causing some confusion.
    Currently I am in the process of upgrading some of our existing servers to newer OS - 2003 R2 (32bit) to 2008 R2 (64bit).
    The existing servers have WMI performance counters for the ProjectWise server component giving information on sessions, connections, DB connection, exceptions, etc.
    After installing the ProjectWise server software on the server (SS2), there are no performance counters also installed. Is there a particular method or are the software components for this located elsewhere?
    Thanks.
    • Sign in to reply
    • Cancel
    • Molly Watts
      0 Offline Molly Watts Mon, Sep 26 2016 4:24 PM in reply to Stephan Searles
      This has to do with the bitness of the server and the application. PW SS2 and SS3 were 32 bit applications that can run on a 64 bit server, however the counters won't be available because of this difference. Starting in SS4, PW is a 64 bit application and you will be able to see the counters on a 64 bit server.
      you may be able to open the 32 bit perfmon from c:\windows\syswow64 and see if they are available there, but I don't have a pre SS4 server available to test that.
      However if the reason you are running these counters is to investigate any sort of performance issue, let us know if there is something we can do to help with that.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Stephan Searles
      0 Offline Stephan Searles Tue, Sep 27 2016 7:20 AM in reply to Molly Watts
      It'd be nice if we/I could capture the PW related counters, but it looks like even though they are in the collection set even the 32bit perfmon doesn't appear to be working. Though it looks like the counters are actually listing where-as they don't in the regular one.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Thu, Sep 29 2016 1:33 PM in reply to Stephan Searles
      On windows 2008 R2, there is a service under services.msc called: “Performance Counter DLL Host” with a description of: “Enables remote users and 64-bit processes to query performance counters provided by 32-bit DLLs. If this service is stopped, only local users and 32-bit processes will be able to query performance counters provided by 32-bit DLLs”. This service defaults to manual startup type, so if it solves the problem, set it to auto.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Stephan Searles
      0 Offline Stephan Searles Thu, Sep 29 2016 1:40 PM in reply to Dana Guthrie
      That did the trick, thank you again!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
