Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Restrict acces to saved searches
    • Sign In
    • State Not Answered
    • Replies 6 replies
    • Subscribers 62 subscribers
    • Views 2713 views
    • Users 0 members are here
    • Saved Searches
    Luc Poulin
    Offline Luc Poulin over 6 years ago
    Hi All
    I there a way to prevent external user to access the saves searches? OR best to allow him to see only specific saved searches?
    • Sign in to reply
    • Cancel
    • Mark Hattersley
      0 Offline Mark Hattersley Thu, Nov 3 2016 2:51 PM
      Hi Luc
      Off the top of my head I do not think so, the best I can suggest is to deny access to the content returned by the search.
      mark
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Thu, Nov 3 2016 3:49 PM in reply to Mark Hattersley
      Ok
      May be I will need to add a requets to have more granularity options to control acces to saved searches and the result
      Thank you
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Nov 3 2016 11:22 PM in reply to Luc Poulin
      the problem is that anything that is done in a saved search can also be done in a regular search so you would have to have access controls for every possible search.
      Searches won't return results for documents that users don't have permission to access. If you need to make sure certain documents won't appear in search results then you need to set document permissions appropriately.
      The simplest search to do is go to right-click the Documents folder, select Advanced Search, click Search Form, then just click OK. That returns every document in the datasource that the user has access to. If you aren't protecting against this search then your documents aren't secure.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Fri, Nov 4 2016 3:00 PM in reply to Kevin van Haaren
      Good info...
      but reading back what i have write.........
      By external users I mean those who use the web client. I can revisit this but from memory when I post this thread....... I was able to get results that give access to documents a user should not be able to view.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • John Schown
      0 Offline John Schown Fri, Nov 4 2016 3:07 PM in reply to Luc Poulin
      Luc,
      The ProjectWise Web Server (and web client) is designed to use the same access control mechanisms as ProjectWise Explorer. So users should not see anything different in Web client than they do in the ProjectWise Explorer client(or anywhere else for that matter). Please double check and certainly get in touch with Support if you find a case where they are not the same.
      HTH,
      John
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
