Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise - Method for exporting folder containing multiple document sets?
    • Sign In
    • State Suggested Answer
    • Replies 1 reply
    • Answers 1 answer
    • Subscribers 60 subscribers
    • Views 2806 views
    • Users 0 members are here
    • ProjectWise export folder folders document set sets
    Christopher Johnson
    Offline Christopher Johnson over 6 years ago
    Hi All,
    I hope I found the right projectwise forumn to ask my question below.
    If I didn't, I am sorry. Please redirect me to the correct place and I will move my post there.
    My question:  Is there a way to export or copy unmanaged (reference copy) multiple document sets from projectwise at the same time?
    Scenario:
    I have a folder in ProjectWise that contains multiple document sets that I would like to export an un-managed copy of to a local drive.
    Failed Case 1:
    Action: Try to export whole folder using wizard
    Result: no documents are exported, just an empty folder
    Failed Case 2:
    Action: Try to select multiple document sets to export,
    result: the option to export is not available in menus once you select multiple document sets
    Desired Best Case:
    action: Select the folder containing the sets, and export
    result:folder is created at destination, then a sub folder is created for each document set that contains all of the files from each of the set
    Alternate working case
    result:folder is created at destination  that contains all of the files from from all of the sets
    Are there any built in tools, or process to accomplish my goals that I missed?
    I have googled and searched the forms to no avail.
    I am sorry If I missed the obvious answer somewhere, but would appreciate y'alls help/ideas.
    ProjectWise Explorer V8i (SELECTseries 4)
    Version 08.11.11.1111
    Thanks in advance,
    Chris
    • Sign in to reply
    • Cancel
    • Bill Kenney
      0 Offline Bill Kenney Wed, Dec 7 2016 5:41 PM
      Christopher, The best tool for Projectwise Export is the Bentley Projectwise Export\Import Tool 8.11.11.11 (for your version of 8.11.11.111) available for download from the Bentley Software Fulfillment site. I am unsure of your term sets - are you referring to PW "Flat Sets" ?
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
