Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum where do we post requests for improvements to project wise explorer?
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 64 subscribers
    • Views 1505 views
    • Users 0 members are here
    • document
    • data store
    • File
    Kevin
    Offline Kevin over 6 years ago
    Project Wise explorer is displaying Document information incorrectly. In Project Wise explorer the document has a file name and the file has size (bytes). In reality, that file does NOT exists on the project wise data store. When the user tries to "work with" (copy out / view etc.) the file - an error message occurs. I issued a support request asking for any procedure that would help in preventing this from happening - SR response  - the situation is unique no such procedure exists - Really?
    If possible, the developers should consider listing document file information CORRECTLY in project wise explorer - In cases where the files does NOT exists on the data store - the document in PW Explorer should display this fact .. NO FILE.
    Thx for reading.
    Kevin.
    • Sign in to reply
    • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Thu, Feb 2 2017 7:49 AM
      You can submit a Change Request (CR) through the Technology Support Group (TSG). Sometimes a Bentley employee will file one based on what is discussed here, or let us know that one has already been filled.
      To your point. The text showing in Explorer comes from the database. That data is gathered on check-in. The file is stored on a hard drive somewhere, not in a database record. The thumbnail is stored in the database. So, something could happen to the file on the hard drive somewhere and ProjectWise not know about it until it attempted to interact with it. If they do implement something like checking the status of every file in a folder when you select it and/or check every file in a search window as it is displayed, I hope it is optional and can be turned off because I think it would impact performance.
      You could write or have someone write a program that runs in off hours which checks every file and creates a report. That way you could figure out where it was happening and hopefully stem the occurrence.
      To clean up the record when this occurs you have to open the properties, click on Advanced options, then select Remove. Then hit Save. That will remove the document name and set the Bytes to 0. You may be able to programmatically do this to clean them up.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Thu, Feb 2 2017 10:31 AM
      Hi Kevin,
      I believe the bigger issue is what is causing the physical file to be removed from the ProjectWise storage area. Have you been able to determine why this is occurring?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Molly Watts
      0 Offline Molly Watts Thu, Feb 2 2017 10:49 AM
      Also, we have a reporting tool that can scan the datasource to find these inconsistencies, if you are interested in that, let us know. But like Brian asked, I think that its important to look into what happened to the file on the server itself.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Yvonne Veltman
      0 Offline Yvonne Veltman Mon, Feb 6 2017 5:12 AM in reply to Brian Flaherty
      Brian, About the cause: We often have a situation that while importing new documents, this action cannot be completed. The cause can be either:
      - time-out due to very big file
      - loosing connection with the network (due to any cause)
      - impatient user canceling the action halfway;
      So the metadata get stored, but the file doesn't. The document gets stuck in 'Coming In'. It can be freed by an Administrator, but the user cannot delete it nor open it. So the Administrator has to delete it AND inform the user to retry the import. I see no use to set the file size to 0.
      This annoying situation happens multiple times each week!
      It would help that while importing a new document, the metadata should be stored and showed only AFTER the file is successfully stored.
      Mind you, it is (at our company) not a matter of an existing file being removed - it simply never got stored.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
