Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Managed Workspace Not Reading Properly
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 60 subscribers
    • Views 3279 views
    • Users 0 members are here
    • Symbology
    • Managed Workspace
    jcallicott
    Offline jcallicott over 6 years ago
    Greetings,
    We have two users - User A and User B. Both have the same versions of MicroStation (08.11.09.459) and PW Explorer (10.00.01.15) running on PW SS4 refresh (08.11.11.574).
    User A can open DGN files and get the Managed Workspace properly.
    User B only gets part of the Managed Workspace - references still come in, but symbology is not correct. No line styles nor fonts work correctly. The workspace is still being read, and shows under Workspace --> Configuration (and also under About Workspace). When querying the Symbology portion of the configuration, both users point to exactly the same set of *.rsc files (the client is not using DGNLIBs). User B has no user-entries for symbology that could override anything. We checked in PW Administrator, and neither user A or B has access to modify personal workspaces.
    Sample output from User B's pwc.log:
    2017-03-27 13:10:50,527 ERROR [0x000048dc] pwise.rulesengine - Failed to read operation list.
    2017-03-27 13:10:50,530 ERROR [0x000048dc] pwise.rulesengine - Required rollback user setting was not found in the settings table. Please contact the system administrator to check if all required settings are defined.
    2017-03-27 13:10:50,532 ERROR [0x000048dc] pwise.server - Error 4 "failed to find handler" reported at func: CategoryDispatcher::Invoke line: 534
    2017-03-27 13:10:50,532 ERROR [0x000048dc] pwise.dms - Request 1 return code -11700. Response size: 0
    2017-03-27 13:10:50,810 ERROR [0x000048dc] pwise.spatial.schema.validation - Spatial datasource status query returned <1004> : No Coordinate Systems In Datasource
    2017-03-27 13:10:55,059 ERROR [0x000048dc] pwise.DgnViewer - failed to create instance of DgnNavigatorAxLib::DgnNavigatorContainer
    2017-03-27 13:17:22,543 ERROR [0x000048dc] pwise.dms - Request 6400 return code 20188. Response size: 0
    2017-03-27 13:17:22,570 ERROR [0x000048dc] pwise.dms - Request 6400 return code 20188. Response size: 0
    2017-03-27 13:17:25,330 ERROR [0x000048dc] pwise.DgnNavigatorAx - expecting an instance of Dgn Navigator Control
    2017-03-27 13:17:25,376 ERROR [0x000048dc] pwise.dgnviewer - expecting an instance of Dgn Navigator Control
    Of note: when B logs onto to A's computer and fires up PW? It works fine.
    So it sounds PC-specific, but I can't nail it down. Any thoughts on this? Thanks!
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Mar 29 2017 1:40 PM
      depending on how configured managed workspaces may still be loading a user's ucf file too. Might check if there are user variables there and not just in the personal workspace.
      I assume you already tried purging all the workspace files on User B?
      Might also be a problem where PW chkl table is out of sync with actual files on the system. Easiest way to fix this is to have the user check in all checked out files. Then close projectwise. Change the user's working directory, and have them log back and say "yes" to creating new working directory.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Kevin van Haaren
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • jcallicott
      0 Offline jcallicott Fri, Mar 31 2017 4:46 PM in reply to Kevin van Haaren
      Kevin,
      Thanks for the reply!
      We tried purging all files (inclusion the workspace) from User B's PC; that didn't do it.
      We then investigated the chkl table possibility by logging out and changing the working directory. Still no dice.
      We renamed User B's UCF to MicroStation.old and let it create a new one. The problem still persisted!
      I appreciate your input... and I'm still scratching my head. Thanks again.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Mar 31 2017 5:07 PM in reply to jcallicott
      you can force microstation to produce a text file of all configuration variables. Create a User Association for MicroStation that adds the -debug command line option.
      the output will show every config file that is loaded and every time a variable is set. It's a bit harder to read a managed workspace one than a regular one but you can still work through it.
      I'd check the variable summary at the end first for something that doesn't look right, then compare against the user that is working to see if you can spot the problem.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
