Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Documents reverting back to Design when Workflow changed
    • Sign In
    • State Suggested Answer
    • Replies 1 reply
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 1102 views
    • Users 0 members are here
    chris oyekanmi
    Offline chris oyekanmi over 6 years ago
    I notice that once a file is Published it can still be reverted back to design at the same version if you change the workflow on the file. This is highly undesirable as is assummed once published this document should not be able to be changed or knocked back to 'Design'.
    • Sign in to reply
    • Cancel
    • Ananthakumar Mani
      0 Offline Ananthakumar Mani Wed, Oct 4 2017 1:15 AM
      Yes, I can understood this issue.
      Could you try with some other files ? Means this issue is facing with only one file or all the files ?
      If it is there in only one file, then you can do the below steps to change the state of the file.
      1. Close the Projectwise
      2. Go to Registry and stop the Workflow rule engine.
      3. Open the Projectwise (there is now workflow rule is working now)
      4. Go to that project and select the file and change the state "Next" Now the drawing file id getting approved.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
