Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum iPlot pen table ignored by MicroStation?
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 60 subscribers
    • Views 1265 views
    • Users 0 members are here
    • WYSIWYG
    • Plotting
    • Ignore pen table
    • IPLOT
    jcallicott
    Offline jcallicott over 6 years ago
    Greetings,
    I have a client-delivered iPlot pen table (*.pen) that I"m trying to use to plot DGN files to PDF. However, my preview and resulting PDFs are acting like no pen table is attached - "what you see if what you get" (WYSIWYG) is what I get when in fact I know all elements should be black. If I detach the iPlot pen table, nothing changes in my plot - it's like it was never even attached.  The proper PLTCFG and PEN files are loaded when I go to print/plot.
    Is there any setting that could be causing this behavior?
    I know the ability for MicroStation to use iPlot PEN files when plotting came in SS3; I am on SS4 08.11.09.829. In case it affects anything, I am in a ProjectWise environment (08.11.11.574 server, 10.00.01.67 client).
    Thanks for any info!
    • Sign in to reply
    • Cancel
    • Andrew Edge
      0 Andrew Edge Thu, Apr 27 2017 8:33 AM
      Make sure you are specifying the IPLOT .pen file in the 'Design Script' field of the MicroStation Print dialog. Not the 'Pen Table' field, which refers to MicroStation pen table (.tbl) files.
      Answer Verified By: jcallicott
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • jcallicott
      0 Offline jcallicott Fri, Apr 28 2017 4:09 PM in reply to Andrew Edge
      Andrew,
      Thank you! The simplest solutions are often best... this worked right away when I tried it.
      The info in your post at communities.bentley.com/.../82381 was also of great help in making sure the iPlot script was correctly specified in the drawings. Thanks again!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
