Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Project Wise trying to map a existing local drive
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 2 replies
    • Answers 1 answer
    • Subscribers 60 subscribers
    • Views 2670 views
    • Users 0 members are here
    • ProjectWise AutoCAD Integration
    Yue Chen
    Offline Yue Chen over 6 years ago
    Our ProjectWise is connecting with Revit. When user clicks the folder icon to open a file, normally ProjectWise will open automatically. And ProjectWise will generate a local disk called Q: drive in local PC. But recently we have a newly mapped drive has the same name. error message pop out every time to say:  it is impossible to map drive Q: since it is already mapped or used by a physical device. The user has to manually delete Q: drive and reopen Revit. is there any way to change Q to some other label name. for example Z or V
    Thank you,
    Charlotte
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Wed, Aug 9 2017 3:32 PM +1 verified
      this is assigned in the projectwise administrator. open administrator, login to the datasource, right-click the datasource name and select properties. When the properties appear, click the Revit Integration…
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Wed, Aug 9 2017 3:32 PM
      When the properties appear, click the Revit Integration. You can assign the drive there.
      Note: this affects everyone in the datasource using Revit. I don't know the affect on Revit files that were using the old drive letter. People with more experience in Revit integration can probably answer that question.
      Answer Verified By: Vickie Ramsey
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Vickie Ramsey
      0 Offline Vickie Ramsey Wed, Aug 9 2017 4:57 PM in reply to Kevin van Haaren
      Kevin, you are correct about there being an effect on the existing files.
      Central Files store the full path for every object in the file. As soon the file is opened from the new drive mapping it will no longer be an editable Central File. It will need to be saved as a new project. Revit doesn't allow a replace so it will need to be saved in a new location or with a new name.
      All in all it might be easier to change the newly mapped drive to a new letter.
      I tend to recommend using B: drive since I haven't seen a floppy drive in use for years.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
