Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Connect Edition Licensing
    • Sign In
    • State Not Answered
    • Replies 10 replies
    • Subscribers 63 subscribers
    • Views 7212 views
    • Users 0 members are here
    caddcop
    Offline caddcop over 6 years ago
    We have been working with a number of clients using ProjectWise Client. We recently we told we needed to use Connect for a new Client. At the end of the install, it told me that our Bentley Hosted License did not contain any valid license for PW Connect Edition and as such, it would run in trial mode.
    What has changed or what is it about PW licensing that I do not understand?
    TIA
    • Sign in to reply
    • Cancel
    Top Replies
    • Marc Canas
      Offline Marc Canas Fri, Jan 22 2021 12:30 AM in reply to Phil Conard +5
      Well i can confirm that this is still an issue in connection client version 11.00.01.19 & Projectwise Explorer version 10.00.03.298 I am fairly certain i have narrowed the problem to Bentley Licensing…
    • Phil Conard
      0 Offline Phil Conard Mon, Aug 28 2017 4:28 PM
      Hi caddcop
      Beginning with PW CONNECT Edition version 10.00.01.67, it will license under the V8i passport entitlement or the CONNECT Edition entitlement.  What version of PW Explorer are you using?  Can you provide a screen shot of the message?  Also, do you know if the PW Admin is requiring you to provide your own license or are you using thiers? That setting is not new to ProjectWise Design Integration, however more organizations are requiring their externals ot provide their own licenses. Below is from the PWCE Update 1 announcement on Bentley Communities:
      New Licensing concept
      This release has a new license capability and it will accept Select entitlements (V8i passport) or a CSS entitlement (CE Visa).  So with that said this is the upgrade path for all existing users regardless of their contract however if they do not have a CSS entitlement then the Cloud services will be gated.   V8i Passport users will get all new maintenance and Application integration improvements
      Phil
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • caddcop
      0 Offline caddcop Mon, Aug 28 2017 4:52 PM in reply to Phil Conard
      Keeping in mind that we have multiple clients, how would we use a client license when offered vs using a passport license when it is not?
      I see 14 Connection Passports on our license file.
      The Help About says the version number is 10.00.02.96
      I only saw the message during activation after install. I do not know how to retry activation for PW. I do not see any license management tools in the PW interface.
      Charles (Chuck) Rheault
      CADD Manager
      • MicroStation user since IGDS, InRoads user since TDP.
      • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Mon, Aug 28 2017 11:45 PM in reply to caddcop
      The admins of the datasource can control if you need to provide your own license or can use one of theirs. It’s a user setting, this is not new with the connect client.
      it sounds like all your previous clients were providing you licenses and this latest one isn’t. The setting controlling this is per user on the datasource.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Phil Conard
      0 Offline Phil Conard Wed, Aug 30 2017 2:04 PM in reply to caddcop
      To check the activation status on your local machine, open the license management tool found in the install directory of ProjectWise Explorer.  The default location is C:\Program Files (x86)\Bentley\ProjectWIse\bin\licensetool.exe.  If you have not already done so on that machine, to enter your select server name and activation key, select tools>options and enter it there.  If you have already entered the server name and activation key, and ProjectWise Explorer is not showing a status of activated in the license tool, you can highlight the application name and select the "activate" button in the lower right hand corner.  If it fails to activate for any reason, the "Status Description" will provide the reason why it failed to activate.
      Phil
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • jcallicott
      0 Offline jcallicott Mon, Feb 3 2020 6:44 PM in reply to Phil Conard
      I know this is some two and a half years later, but I've got an odd situation that relates to this question.
      We are working with a sub- a small shop - and they own one PW CONNECT License on a CSS. When they connect to other, larger firm's datasources, no issue. Yet when they connect to ours - which is set to have users deliver their own PW licenses - they get Error 58510, indicating "Your ProjectWise use profile requires that you activate this ProjectWise product using the SELECTServer setting configured on this workstation." Thing is, they can't - they never received an activation key, as their products do not license using SELECT Server; it's all Subscription Entitlement Service (SES) through CONNECTION Client. They received Error 58510 running the 01.67 build, and still do with the 03.262 build.
      I had the user run the license management tool (C:\Program Files\Bentley\ProjectWise\bin\licensetool.exe), and it shows no licenses at all. I assume this is WAD because their licenses are SES based. I also asked the user to provide their license log, and another error came up indicating "License Log filnot found. Please run your application first."
      I strongly suspect the larger firms are extending PW usage to this small company. Is there a reason the PW Explorer software would refuse to license on an older Integration Server (V8i SS4 refresh)? I am able to license fine on our datasource using the 03.262 build, myself. Might there be any other reason for what we're seeing?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
