Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum While opening a file from Projectwise, it is "receiving changes" for reference files that were not updated in a while. Why?
    • Sign In
    • State Verified Answer
    • Replies 5 replies
    • Subscribers 61 subscribers
    • Views 3510 views
    • Users 0 members are here
    • MicroStation
    • Slow
    • delay
    • ProjectWise
    Vinod Balakrishnan
    Offline Vinod Balakrishnan over 5 years ago
    I run PW 10.00.01.28. I have noticed this issue that happens once in a while. It is better explained with a example.
    Consider file VBWorking.dgn. The very first time I had to open this file, Projectwise took a while to open it  - I understand this is because it has to download all the reference files attached to VBWorking.dgn to my local drive. Lets say I have been working on this file everyday for 22 days now. On day 23, I open VBWorking.dgn and it is taking a while to get past the window that says "Receiving changes for xyz.dgn (1/50)...". It goes on to receive changes for all of the 50 reference files attached to it. And instead of just receiving changes, I believe it might be trying to re-download the entire reference file.
    I am quite sure that not all of the 50 reference files attached to it have been revised since the last time file VBWorking.dgn was opened. I am also sure that the reference files previously downloaded to my local drive were not deleted. I do not understand why Projectwise is trying to receive changes that were not made in the first place.
    This is not such a major issue when I am working in the office and directly conencted to the company network - the dgn will load up in 5 minutes or so. However, it becomes a "work stoppage" issue when I am working remotely and connected to the company network via a VPN. The files are stuck forever in the "receiving changes" mode because these are large reference files. Internet connection speeds play a role - I understand.  But this issue, in my opinion, can be avoided if PW doesn't try to "receive changes" for reference files that were not updated at all.
    Am I doing something incorrectly and causing this issue? Could you please explain if this is normal?
    Please see the attached screenshot for reference. Thanks,
    Vinod
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Mon, Dec 4 2017 10:49 AM +1 verified
      The user setting "Use up to date local copy on copy out" affects this too. If turned OFF then reference files will always be copied out, even if the local copy is up to date. If, as JROD points out, "Enable…
    • Joe Rodriguez
      0 Offline Joe Rodriguez Mon, Dec 4 2017 9:41 AM
      Have your Projectwise administrator check if your user settings have "Enable Delta File Transfer" checked on, this setting is under the Network User settings in Projectwise Administrator module.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Mon, Dec 4 2017 10:49 AM
      The user setting "Use up to date local copy on copy out" affects this too. If turned OFF then reference files will always be copied out, even if the local copy is up to date. If, as JROD points out, "Enable Delta File Transfer" is off then every single bit of the file has to be copied to your machine. Very slow.
      Answer Verified By: Vinod Balakrishnan
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Vinod Balakrishnan
      0 Offline Vinod Balakrishnan Mon, Dec 4 2017 4:46 PM in reply to Joe Rodriguez
      Thank you, JROD. I'll run this by our admin!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Offline Vinod Balakrishnan Mon, Dec 4 2017 4:46 PM in reply to Kevin van Haaren
      Thanks, Kevin. I'll run this by our admin!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Offline Vinod Balakrishnan Tue, Feb 13 2018 11:46 AM in reply to Kevin van Haaren
      Kevin - it was the "Use up to date..." option that solved the issue.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
