Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ICS_for_PDF_workdir
    • Sign In
    • State Suggested Answer
    • Replies 6 replies
    • Answers 2 answers
    • Subscribers 60 subscribers
    • Views 2174 views
    • Users 0 members are here
    ICS_for_PDF_workdir
    Jeff Bowlin
    Offline Jeff Bowlin over 5 years ago
    Can the data in this iCS server folder be deleted?
    • Sign in to reply
    • Cancel
    • Jeff Bowlin
      0 Offline Jeff Bowlin Thu, Mar 22 2018 11:22 AM
      ...or the \pwdsjob_workingdir folder?
      Jeff
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Mar 22 2018 2:19 PM in reply to Jeff Bowlin
      • use the bentley ics admin
      • right-click the working directory
      • click disk usage option
      • highlight all the items, click clear cache button
      this does not remove 100% of the files in the working directory but does get 99%. I was told to only use this method for clearing files. I've never tried deleting files/folders manually.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Edge
      0 Andrew Edge Fri, May 18 2018 11:20 AM
      As long as no jobs are currently active, it is safe to manually delete the numeric subfolders under the iCS working directory.  The owner.txt file and non-numeric subfolders should be left alone.  Manual deletion is often faster than using the command in the Administrator program, but the Administrator command will leave the files in the job history subfolders untouched.
      Deleting the contents of the working directory for a given job, whether manually or via Administrator, will force that job to run as a full job on next invocation.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Jeff Bowlin
      0 Offline Jeff Bowlin Fri, Jan 25 2019 9:12 AM in reply to Andrew Edge
      Resurrecting an old one.....
      I'm encountering disk space issues and would like to better manage the iCS for PDF working directory, rather than manually using the GUI.
      Is the working directory continually increasing in size, or, does it decrease in size as jobs complete?
      Is the best way to deal with disc space issues that are directly related to this folder to increase the size of the disc, or, purge methodically?
      Would a deletion script keying on dates, for example everything older than a week, be of any use in managing disk capacity issues?
      Thanks in advance,
      jlb
      Jeff
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Edge
      0 Andrew Edge Fri, Feb 1 2019 11:26 AM in reply to Jeff Bowlin
      The working directory continually increases in size as new documents are extracted.  There is no automatic pruning mechanism.  However, recent releases have included an undocumented configuration property to force deletion of the job working directory after completion, similar to the behavior of jobs submitted from ProjectWise Explorer.  The downside is more time spent copying out documents for every job run, especially for jobs containing lots of references that don't change very often.  Plus loss of delta file transfer benefits for large files that change slightly.
      The property name is "DeleteJobDirOnCompletion" with value "1" in the "rendsvcConfiguration" table of the Orchestration Framework database.  It was introduced in early 2016.  I don't know offhand what release that corresponds to, but it would be fairly recent CONNECT Edition.
      A scheduled task that periodically prunes the working directory is fine in theory but could get tricky.  You'd have to be careful not to delete any files currently in use by a running job -- which might be difficult to determine as a border reference copied out and unchanged for months or years could still be referenced by every active job.  Making sure the job was idle before pruning would be best, but that would require programming not just dumb scripting.  You'd also want to avoid deleting the history files if you cared about them, and definitely leave the product files in the non-numeric subfolders alone.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
