Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Unmanaged ProjectWise - Controlling Workspace
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 61 subscribers
    • Views 1670 views
    • Users 0 members are here
    • workspace
    Tom Felcone
    Offline Tom Felcone over 5 years ago
    Working on another companies PW server and they are not using managed workspaces.
    I am pointing my folks to the workspace using TOOLS > ASSOCIATION > PROGRAMS and modifying the command line to start the workspace.
    This works fine until someone needs to use the workspace of another client. Then it's back to TOOLS > ASSOCIATION > PROGRAMS.... This is clunky at best.
    Is there better way to do this?
    Tom F.
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Apr 25 2018 1:18 PM
      how is the other company defining what workspace should be used?  For example we set the Project Configuration File Name field on the MicroStation Settings tab of the Workspace Profile. If the company you're working with does the same, then create a PCF file at the same location your other PCFs go with the same name the other company says to use. Inside that PCF you can do whatever you want including a %include of your real workspace.
      your users would then just open the files normally in projectwise and your PCF, named the same as theirs but with different content, would be loaded.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Tom Felcone
      0 Offline Tom Felcone Wed, Apr 25 2018 4:25 PM in reply to Kevin van Haaren
      Kevin,
      Gotcha. How do I check this from PW explorer? Riight Click on the folder and go to Properties (don't have access to the project myself)
      Tom F.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Apr 25 2018 10:54 PM in reply to Tom Felcone
      Can't remember if this is a user setting, but right-click the folder > properties. THen click the WorkSpace tab. The drop down should default to WorkSpace Profile.  Under MicroStation-specific settings are what it sets when launching microstation.
      The workspace profile can be changed on a folder by folder basis, so best to check the folders with the files that will be opened.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
