Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Working directory when using ProjectWise Explorer possible with %localappdata% in Users Properties?
    • Sign In
    • State Verified Answer
    • Replies 5 replies
    • Subscribers 61 subscribers
    • Views 3560 views
    • Users 0 members are here
    • Projectwise Explorer
    • working directory
    • ProjectWise
    Christian Jührendt
    Offline Christian Jührendt over 5 years ago
    i'm setting the configuration of the User Properties in the ProjectWise Administrator on the server (CE3). So i need to change the "Working Directory" "When using ProjectWise Explorer". I'm wondering about the "%localappdata%" because it is used in the standard setting but on the client with ProjectWise Explorer (SS4) it does not work. Is this variable available in the path configuration or not? In the help file it's not mentioned for the "When using ProjectWise Explorer" but for "When using ProjectWise Web Server". The message on the client is something like "Working directory %localappdata%\xyz does not exist. Do you want to create it?" -> Yes -> "Can not create a directory. Full pathname is required to perform this operation.". The setting "Allow user to change working directory" is off. If use %localappdata% in the windows explorer it goes to "C:\Users\userX\AppData\Local" were i can create the required folders.
    I hope someone has an idea
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Tue, Jun 26 2018 10:56 AM in reply to Kevin van Haaren +1 verified
      the way i read the help you can only use: $User.Name$ — the user's ProjectWise user name $User.Descr$ — the user's description $User$ — the user's number in the datasource in the working directory…
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Jun 26 2018 10:35 AM
      in PW V8i you couldn't use environment variables in the Working directory specification. Sounds like this changed in Connect Edition? Upgrade the client and see if it works.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Jun 26 2018 10:39 AM
      hmm, doesn't work for me with Servers at 10.00.01.67 and client at 10.00.03.49
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Tue, Jun 26 2018 10:56 AM in reply to Kevin van Haaren
      in the working directory for projectwise explorer. Note - if you have external users don't try and use the localappdata by hard coding: c:\Users\$User.Name$\AppData\Local - your projectwise username probably won't match the external user's computer username and it'll try creating the folder under c:\Users and lead to a lot of weird issues (in our experience, any way)
      Answer Verified By: Christian Jührendt
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Christian Jührendt
      0 Offline Christian Jührendt Wed, Jun 27 2018 4:46 AM in reply to Kevin van Haaren
      Yeah that's what i read in the help file too. But the %localappdata% thing was preconfigured in a new ProjectWise server installation so i was really wondering.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Stephen Herrick
      0 Offline Stephen Herrick Wed, Jun 27 2018 2:17 PM in reply to Christian Jührendt
      Hello Christian,
      I am using %userprofile%\documents\...... and it is working, as Kevin noted, though it isn't documented, so probably not supported but it does work for my deployments, CE .99
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
