Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Attribute fields in Office 365
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 60 subscribers
    • Views 1688 views
    • Users 0 members are here
    • ProjectWise
    • integration
    • Office 365
    Ole Bro
    Offline Ole Bro over 5 years ago
    After a succesful integration of attributes from Projectwise to Microstation, i'm starting to look at a similar integration between Projectwise and Microsoft Word.
    Creating the Attribute Exchange Rules for Microsoft Office are identical as to create Attributes for Microstation, but I haven't figured out how to create the receiving data fields in Microsoft Word.
    I'm sure that it isn't complicated, but I simply can't find the dialog where I can define the data fields.
    Are there someone who can point me in the right direction?
    Thanks in advance.
    Ole Bro
    • Sign in to reply
    • Cancel
    • Rippster
      0 Offline Rippster Wed, Sep 5 2018 2:07 AM
      1. In Word select the File menu then Info
      2. Click Properties towards the right and select Advanced Properties
      3. Click the Custom tab then start filling in the fields as per your Attribute Exchange Rules (Name, Type, Value) then click Add button for each field
      4. When complete click OK then click the Back arrow to return to your Word document
      5. Select the relevant location on the Word document for the first field you want to add
      6. Select Insert menu from the ribbon and then Quick Parts then Field...
      7. in Categories select Document Information
      8. under Field names select DocProperty
      9. under Field properties select one of your Properties you created in step 3 then click the OK button
      repeat steps 6 to 9 for each field
      Good luck!
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ole Bro
      0 Offline Ole Bro Wed, Sep 5 2018 9:33 AM in reply to Rippster
      Thanks... I will try that.
      ORD Connect:10.08.01.033
      MS Connect: 10.14.02.01
      Projectwise: 10.00.03.49
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
