Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum PW Share
    • Sign In
    • State Suggested Answer
    • Replies 1 reply
    • Answers 1 answer
    • Subscribers 60 subscribers
    • Views 1039 views
    • Users 0 members are here
    PW Share
    Rob Brawn
    Offline Rob Brawn over 4 years ago
    PW hosted at Bentley. Share has never been activated so this is first time. Turn on share in Connection client. Try to create a connection in the cloud. Enter URL. I see data sources so that works. Use my login. I'm an admin. Forms says no work areas. I go to PWC and see the work areas in PWC. An y ideas why I cant see any work areas?
    • Sign in to reply
    • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Mon, Jan 21 2019 7:56 AM
      Hi Rob,
      There is a configuration you can do to make things easier. Navigate to your ProjectWise Administrator you will see a setting in the settings tab that you place a WSG 'Project' URL. (steps in the implementation guide) Once you you do this (Only one time configuration) Any time you associate a Work Area to a  ProjectWise Project to you will create a connection in Share automatically. Now if you want to manually create connection you can do so as well you'll need a WSG/PWplugin (delivered in ProjectWise Design Integration Installer)
      main reason you do not see it is because you can only associate to a work area you have probably already created a Association to a ProjectWise Project hence it does not show in the work area list.
      ///Ranveer
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
