Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjecWise not checking out documents
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 61 subscribers
    • Views 2403 views
    • Users 0 members are here
    • ProjectWise Office Integration
    • ProjectWise Documents
    • check out
    Amber McCullough
    Offline Amber McCullough over 4 years ago
    One of our users opens a pdf and ProjectWise does not check it out. Consequently his changes only go to the local copy and when he closes the document, it doesnt update the ProjectWise copy.  Is there a setting for this?  Other users work as expected with the same document. If it matters, its bluebeam pdf program.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Jan 11 2019 5:54 PM +2 verified
      does it happen for all documents for the user, or just PDFs? If it's for everything it may be they changed the default double-click action. This is under Tools > Options > Settings tab. Document List …
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Fri, Jan 11 2019 5:54 PM
      does it happen for all documents for the user, or just PDFs? If it's for everything it may be they changed the default double-click action. This is under Tools > Options > Settings tab. Document List > Double Click Action. If it's set to Open Read-Only you would see this behavior.
      if it's just happening in bluebeam, are they by chance using the built-in bluebeam/projectwise integration and opening documents from inside of bluebeam? If so they may have left the "Checkout on open" option off when setting up the connection. You can check this in Bluebeam under Settings > Preferences > File Access. If it lists a datasource edit it and see if Checkout on open is turned on (also turn on Checkout on open from hyperlinks).
      Answer Verified By: Amber McCullough
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Amber McCullough
      0 Offline Amber McCullough Mon, Jan 14 2019 12:31 PM in reply to Kevin van Haaren
      Great, thank you. Exactly what I was looking for.  It was with bluebeam only and we have it running. Thanks!
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Amber McCullough
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
