Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise switching Autocadd Reference files
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 61 subscribers
    • Views 1158 views
    • Users 0 members are here
    Tony Cacciola
    Offline Tony Cacciola over 4 years ago
    How can we detach a reference file in a drawing and add a different one thru Projectwise without opening an autocad session ?
    Detach a file and add a new reference file thru Projectwise.
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Feb 1 2019 5:17 PM
      You can't. You can replace the existing projectwise reference with another file in projectwise, but you can't detach and then attach a new reference without opening AutoCAD (or MicroStation) to do it.
      To replace a reference file in Projectwise:
      • Right-click the existing reference in PW, select Properties
      • In the File section under the General tab is an Advanced button, click that
      • If the file you want to replace the existing reference with is outside of ProjectWise select Import
      • If the file you want to replace the existing reference with is inside of ProjectWise select Replace
      • Select the file to replace the existing file with
      • Tell it to use the Original Filename
      • Click the Save button
      • Click the Close button
      If you want to retain a copy of the existing reference first version before doing the above by by right-clicking the reference, select New > Version. After creating the version do the steps above on the master version of the reference.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
