Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Autocad drawing is opening in editable mode when opened in "READ ONLY"
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 62 subscribers
    • Views 1090 views
    • Users 0 members are here
    • ProjectWise AutoCAD Integration
    • Bentley
    • ProjectWise Documents
    • Application integration
    Govardhan chindam
    Offline Govardhan chindam over 4 years ago
    Hello all when a USER is opening the Autocad document in READ ONLY mode, the drawing is getting CHECKED OUT , the problem is occurring only to a particular user
    i have loged in to the same Machine with my ID, its working fine, seems its the user specific problem
    Can you please let me know the solution or the clue
    Thanks & Regards,
    Chindam
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Online Kevin van Haaren Tue, Feb 26 2019 4:10 PM
      1. verify the user is really opening the file in read only mode from ProjectWise.
      2. Check the audit trail on the file, if it also says the user checked out the drawing, then something is causing the document to be checked out. might be something in the autocad integration.
      3. Boost logging in the odma.log.xml. it has some categories specific to autodesk integration that might provide details.
      4. open a ticket with Bentley.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Govardhan Chindham
      0 Offline Govardhan Chindham Sun, Jun 5 2022 7:58 AM in reply to Kevin van Haaren
      Hi Kevin,
      1. Either  click in “Open” or “Open as Read-Only”, it triggers the application which is associate under “Open” option, Can separate configurations be made for Ready only to trigger different applications ?
      2. Can we disable Read only option in PW ?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Madhuri Londhe
      0 Offline Madhuri Londhe Mon, Jun 13 2022 4:58 AM
       There is a user setting (Document List > Double click action) that controls what happens when you double-click a document in ProjectWise Explorer. By default the double-click action is set to open documents, but you can change that to another action, such as Open as read-only, or your administrator may have hidden this user setting and set a default for you.
      Please refer below link for more information.
      https://docs.bentley.com/LiveContent/web/ProjectWise%20Explorer%20Help-v11/en/GUID-4494D967-B687-FB20-0EF8-B93AE616ADD0.html
      Thanks.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
