Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum MicroStation versions compatible for use on ProjectWise Design integration, ICS for PDF and Indexing servers
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 61 subscribers
    • Views 712 views
    • Users 0 members are here
    • ProjectWise Document Processing
    • ProjectWise Install
    davhum75
    Offline davhum75 over 4 years ago
    Has anyone had success using the Connect Licensing editions of MicroStation (and View) for document processing on the server.?
    I have had issues with it when used for ICS for PDF publishing engine. Haven't tried it yet for FTR, Property Extraction, Thumbnail generation as yet.
    The reason for asking is that The Connect Licensing version are the only ones that I can download currently.
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Mar 28 2019 8:52 PM
      I was unable to get microstation connect to work with ics but I was trying to smash our unmanaged  v8i workspaces into connect with minimal effort. I gave up and went with microstation v8i and will revisit on our Dev server eventually.
      unfortunately that means we can’t support autocad files newer than 2016 and I was hoping 64-bit microstation would be able to process some huge files we have that ICS with v8i can’t.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Edge
      0 Andrew Edge Fri, Mar 29 2019 10:13 AM
      iCS for PDF CONNECT Edition Update 3.1 is certified to work with MicroStation 10.12 and 10.11.  What sort of issues are you referring to?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
