Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Files Generated Using AecoSIM On ProjectWise
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 61 subscribers
    • Views 443 views
    • Users 0 members are here
    • AECOsim
    • ProjectWise
    Arron Tucker
    Offline Arron Tucker over 4 years ago
    Hi All,
    Forgive my ignorance, I'm predominantly an Autodesk user but I've been tasked with managing Bentley products under my current role.
    Currently we are receiving quarterly charges for the odd use of AecoSIM which does not fall under our current license agreement. After some digging the reason I'm been told is the drawings sat on ProjectWise (by others) have been created in AecoSIM therefore when opening them it will default to AecoSIM.
    Few questions.
    1. Is this true?
    2. Can the files be opened in another software from ProjectWise? i.e Microstation
    I've used ProjectWise in a previous company but I was working mainly with Microstation and uploading to the CDE.
    Arron
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Online Kevin van Haaren Tue, Apr 9 2019 8:26 AM
      It's possible to set files to open in aecosim from Projectwise. I'm not sure if aecosim has additional file types other than dgn but it's also possible to set dgns to say they require aecosim. However if aecosim is not installed on the machine, it either won't open or will ask what product to use. It won't say you've launched aecosim and count a license for it.
      So basically the problem is tangentially Projectwise, the real problem is users with aecosim installed that don't need it. On select sever you can run a report on who and what machine is running it. Uninstall aecosim on those machines.
      If you really do have aecosim files, I'd ask on the aecosim forum about how to use them.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Online Kevin van Haaren Tue, Apr 9 2019 11:03 AM in reply to Kevin van Haaren
      I just checked my Dev datasource, there are 3 AECOsim applications listed in the default Applications configuration:
      • AECOsim Building Designer
      • AECOsim Building Designer - Energy Simulator
      • AECOsim MicroStation
      My guess is the AECOsim MicroStation should open in MicroStation without problems (although there may be elements you can't edit). Not sure on the other 2.  By default none of these are assigned extensions (that means no files will automatically be assigned this application).
      Files can be individually assigned to an application. If you right-click a file, select properties you'll see the application in a drop down on the General tab. You can then manually force it back to MicroStation.
      You can do a search across your entire datasource for all files assigned to the AECOsim MicroStation application, then select them all in the results window and use the Modify command to change them all to MicroStation in one go.
      This won't prevent people from accidentally launch AECOsim though. Still best to remove it from their machine if it shouldn't be used.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
