Moving files changes state?
I need to move a large number of files (Including superseded files)
When using "move to.." or cut Paste, it will move the files, but the workflow state is changed to the initial state, "work in Progress" even for the superseded files?
Does anyone know how to move and keep the original state?
Files are moving within the same work area and the folders have the same environment's applied.
I have seen other threads on this from 5 years ago, with no solution.
Brian
