Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ICS Improvements to Multi-File processing
    • Sign In
    • State Not Answered
    • Replies 8 replies
    • Subscribers 62 subscribers
    • Views 2251 views
    • Users 0 members are here
    • iCS for PDF
    Warren Malveau
    Offline Warren Malveau over 4 years ago
    In ICS, I can select individual DGN files and submit a job from an ICS profile  that doesn't ask me about the ICS printer, but does have me select a pre-determined settings file from ProjectWise.  Works Great!!!
    To make renditions from IPS files, the ICS printer must be specified in the IPS file, and the plots must have a settings file applied from ProjectWise.  Selecting a profile from the ICS profile dialog is not an option (grayed out).  This is time-consuming preparation, with the only real savings being PDF generation.  It would be faster to just select the individual DGN files, then use an ICS profile to process them.  The only drawback is that the renditions from individually-selected DGN files cannot be placed in a multi-page PDF by ICS.
    Is there any chance that ICS will be enhanced to use the IPS file solely as a list of files, and allow the user to select a Presentation from the ICS profile dialog?  Or will it be enhanced to allow individually-selected DGN files to be rendered into a single multi-page PDF?
    • Sign in to reply
    • Cancel
    Top Replies
    • Warren Malveau
      Offline Warren Malveau Mon, Jun 10 2019 7:20 PM in reply to Andrew Edge +1
      Andrew, Your suggestion is exactly what I have been doing. On the ICS server, I created a printer for ICS (LACSD_ICS_Printer) that uses our preferred KIP860 driver. Works great! Only problem is still…
    • Andrew Edge
      0 Andrew Edge Wed, Jun 5 2019 12:05 PM
      The latter presents a host of difficult user experience difficulties.  Aside from needing to add a non-trivial page order control to ProjectWise Explorer's Create Renditions dialog, multiple sheets per DGN and per model are common.  In order to present the sheets for proper sequencing, the DGNs would first have to be copied out and examined -- an expensive operation.  Even more difficult if logic in the settings file has to be applied in order to find and filter print boundaries from shapes in the model; PW Explorer does not currently have that capability.  The PWE Create Renditions dialog wasn't intended to replace the full functionality of InterPlot Organizer.
      Your first suggestion would be more easily accomplished.  However, in a well-standardized environment, the majority of the work involved with creating and maintaining an IPS file is keeping the DGN/sheet list up to date.  Presumably the same .set files used in the iCS for PDF rendition profiles are available to the administrator maintaining the IPS file and would be used.  I can see some benefit in allowing the contents of an IPS to be renditioned from PWE using different a Presentation, but it doesn't seem like it would be a feature much in demand.  Most of the time I'd expect the IPS to already be configured with the proper Presentation, and of course with the sheets already arranged.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Warren Malveau
      0 Offline Warren Malveau Thu, Jun 6 2019 12:19 PM in reply to Andrew Edge
      In our shop, a lead designer updates and maintains a project IPS file all to way until submittal time.  For us, it is the definitive list of all sheets to be plotted for the project.  Typically, the printer is set for one of our physical printers, along with a matching printer settings file from the IPlot server is applied.
      When our designers want to use ICS to quickly create a rendition of existing IPS plot set, they have to open the IPS file, change the printer, apply a settings file from the ProjectWise (not the IPlot server), save and check-in, then run IPS.
      Warren J. Malveau
      Senior CADD Support Specialist
      Los Angeles County Sanitation Districts
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Edge
      0 Andrew Edge Fri, Jun 7 2019 2:10 PM in reply to Warren Malveau
      I assume the problem is that the driver for the physical printer uses a set of custom paper size names different from the standard Windows forms database.  To deal with that, you can install the same printer driver on the iCS for PDF server, create a Windows printer using that driver (you can set the port to FILE if the server can't see the physical printer), configure InterPlot to use that printer instead of the generic ProjectWise printer it creates (look for IP_DCS_RENDITION_PRINTER in C:\Program Files (x86)\ProjectWise InterPlot Organizer\config\ip.cfg), then use the same .set files for PDF creation as you use for physical paper output.  The workflow you describe definitely should not be necessary.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Jun 7 2019 2:26 PM in reply to Andrew Edge
      We create a virtual printer queue on every plot server using the same driver and having the same name on each server, this printer is configured to plot to the NUL: port so it never actually prints anything that goes to it. We also setup a set of sheet sizes on every plot server. We do the same on our ICS server.
      We recommend our users using InterPlot Organizer or Print Organizer to create PDFs to use that printer in their IPS/PSET files. If they are creating a IPS for use with renditions we tell them to specifically use the VirtualPlot queue shared from the ICS server.
      We also put:
      printer=\\ics_server_name\print_queue
      in every SET file we setup for use with ICS.
      About the only thing we have to do for this system now is add the occasional odd paper size that we don't already create.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Jun 7 2019 2:29 PM in reply to Kevin van Haaren
      We also discourage our users from using IPS files for ICS because they've been unstable for us. Not sure what it is about our workflows that cause this but we find IPS files just stop working after a while.
      We now try to setup renditions so users can just right-click on a file (or set of files), select Create Rendition and then Click OK and get exactly what they need for that project.  No need to mess with an IPS file at all. We typically use either the Sheet Model name or Sheet Description name for the PDF file name depending on the project.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Warren Malveau
      0 Offline Warren Malveau Mon, Jun 10 2019 7:20 PM in reply to Andrew Edge
      Andrew,
      Your suggestion is exactly what I have been doing.  On the ICS server, I created a printer for ICS (LACSD_ICS_Printer) that uses our preferred KIP860 driver.  Works great!  Only problem is still having to visit that IPS file to change printers and apply settings file from PW server.
      You're providing a lot of good detail that doesn't appear to be document.  Or am I not looking in the right place.
      Warren J. Malveau
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Warren Malveau
      Andrew,
      Warren J. Malveau
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Edge
      0 Andrew Edge Tue, Jun 11 2019 11:01 AM in reply to Warren Malveau
      I'm not the best person to ask about documentation.  Like all documentation, I'm sure it could be improved.  The challenge for a writer is to ensure a basic explanation of what the product does while not being so verbose and detailed that nobody actually reads it (with that threshold seemingly going down rapidly).  When you start getting into the nitty-gritty, the style of documentation has to change; you end up needing blog-type articles on specific topics that are difficult to anticipate in advance.  IMHO that's why formal documentation on complex systems ends up being relatively sparse with forum threads and other channels picking up the slack.  Not ideal but just a fact of life.
      The idea is that creating renditions from an IPS using iCS for PDF should not be very different from doing so from different PCs using InterPlot Organizer.  Just treat the iCS for PDF server as another user PC.  You can use a shared network printer connection on all the PCs as Kevin van Haaren suggests.  Or just create local printers on each PC and make sure they are named the same.  If you use the same printer driver, every PC will be on the same page concerning paper size names.  There should be no reason to have to edit the IPS every time it needs to be printed/renditioned from a different PC.
      One ugly bit is that you need to edit ip.cfg on the iCS for PDF server to set IP_DCS_RENDITION_PRINTER to specify the name of your custom printer.  Otherwise it will use a generic printer with the standard Windows paper size names.  In the upcoming release, this configuration will be more visible in iCS Admin and can be accomplished without having to mess around with text files.
      The design also doesn't work well if you have a single iCS for PDF server that serves multiple offices with different physical printers using different drivers with different paper sizes.  It would be nice if InterPlot Organizer supported abstract paper sizes not tied to a particular Windows printer, but it doesn't.  In that case, the printing situation likely already requires multiple IPS and settings files: one for each office.  Adding iCS for PDF to the mix would require choosing one printer to target for server renditions and making that office responsible for managing the IPS/.sets for server renditions.  Or adding IPS/.sets that target the generic "ProjectWise Dynamic Composition Server" printer.  In practice, that scenario doesn't come up often.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Warren Malveau
      0 Offline Warren Malveau Tue, Jun 11 2019 12:20 PM in reply to Andrew Edge
      If I may, let give a an example of our IPS file use:
      • On a given project, the ELEC group creates an IPS file that lists 10 sheets.  The printer is set to a shared B-size laser printer on the IPlot server, and a matching printer settings file from the IPlot server is applied.  Users can now print the sheets to the laser printer.
      • if the user then wants to print to a large-format shared printer instead,  he must open the IPS file, change to the shared large-format printer on the IPlot server, and apply the appropriate printer settings file from the IPlot server.  He can not print from the current IPlot  Organizer session without saving the IPS file.
      • If the user instead wants to create a rendition of the IPS file, he must open the IPS file, change the printer to the shared ICS printer on the ICS server, then apply an appropriate settings file from ProjectWise.  The revised IPS file must be SAVED back to ProjectWise, and now renditions can be created (noting that "Presentation" is not a selection option).
      • Finally, if for some reason someone needed to print directly to the shared laser printer again from the IPS file, the IPS file would have to be revised again.
      I understand having to change printer and printer settings to print hardcopy to different printers.  I find it unfortunate that the same has to be done for creating renditions from IPS files.  It would be great to leave the IPS file as-is, and enable the Presentation choices the Create Rendition dialog.  Just a suggestion.
      Your suggestion and Kevin's for IP_DCS_RENDITION_PRINTER and shared ICS printer are good.  I already implement these.
      Warren J. Malveau
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
